How crucial are inside wall angles on the sealed side? - Car Audio Classifieds!
Old 11-10-2013, 08:44 PM
Robertvon's Avatar
0/11 ssssss540
Default How crucial are inside wall angles on the sealed side?
I would like to know if the insde angles of the sealed side of a 4th order effect its performance or is it just based on total internal volume?
The reason I'm asking is if I build my enclosure with multiple angles insted of a square box and use the spare tire well to fire into I can gain 2.25 cuft. and with trying to crame 2 15's in a trunk that would help out ALOT!
So give me your thoughts and input!
Old 11-11-2013, 12:34 PM
n8skow's Avatar
0/11 sssss1519
Angles on the sealed side just *affect your internal volume.
National Finals - Oct. 29th & 30th, 2016 in Sedalia, MO
Old 11-11-2013, 12:41 PM
dirt101's Avatar
0/11 ssssss956
In my opinion they are not too critical, and even if they were, I feel like gaining that kind of cubes would 100% outweigh negative affects of the angles.
Old 11-12-2013, 03:41 AM
0/11 sssss5305
Only issue "could" be if 1/2 the rear wave of a sub hits the rear wall way before the other 1/2 does.
If subs are upfiring and part of the rear wave hits at trunk level and the other part hits in the bottom of the spare tire well you "might" get coil rock/shred cones. Usually only an issue on high power but I have seen this happen before.
Hope that made sense, sort of hard to explain....
Old 11-12-2013, 07:31 AM
Robertvon's Avatar
0/11 ssssss540
if sealed side "tire well" is uniform would it prevent this ? They will see some good power
Tags
15" subs, 4th order box
Sealed wall in a convertible tez4life General Car Audio Discussion & Questions 2 10-25-2012 07:53 PM
Sealed wall? Fatboy501 General Car Audio Discussion & Questions 43 10-27-2011 06:42 AM
A peek inside my wall walled01alero Car Audio Videos 0 07-09-2011 11:01 AM
loading wall inside box? Xtremelegend General Car Audio Discussion & Questions 10 06-09-2011 06:16 AM
8 12s in a sealed wall?? Yes/No BigC-Expo General Car Audio Discussion & Questions 16 08-01-2010 12:26 PM
