quick 6th order ? - Car Audio Classifieds!
Old 11-16-2013, 05:27 PM
mega fatty
0/11 sssss6008
Default quick 6th order ?
so i just got a 99 blazer and im looking to do a build this spring. Hopefully this vehicle will last longer then my last attempt at a build
im thinking 10cf tuned to 25 with 2 6" aero's, and 25cf tuned to 50 with a 30"x18" port.
meow i just cant decide on what subs to go with.....
i have
6 oa 12's d4
2 sundown Zv1's 15's(one needs a recone) d2
2 apx motors (872) i could build into 18's
or sell a bunch of stuff and try to find some decent 18's or dp 21's, or find 4 15's
all will be powered by a D9 for now, hopefully 2 or just a big amp in the future
goal would be loud daily driver
07 mazdaspeed3
rd d9 @ .5ohm
Old 11-16-2013, 05:38 PM
jt_buck's Avatar
don't shoot
0/11 sssss4423
Toooooo low imo.
Old 11-16-2013, 05:43 PM
mega fatty
0/11 sssss6008
i did think it was a bit low, but i listen to alot of decaf and c/sed...
a quick model in winisd and bbp6 showed a peak around 49hz with a nice roll off to about 32hz before it dropped below 0db gain.
also the f3 on the low side is supposedly around 45 so that should fill in nicely with the front tuning.
maybe i will bump it up to 30hz on the rear tuning. either way it should still get down.....
07 mazdaspeed3
rd d9 @ .5ohm
Old 11-17-2013, 06:46 PM
mega fatty
0/11 sssss6008
Any other opinions?
12's have cone area but then I gotta buy 6 subs when I upgrade but 2 18/21's would cool, I just have to sell stuff first
07 mazdaspeed3
rd d9 @ .5ohm
Old 11-17-2013, 06:48 PM
jt_buck's Avatar
don't shoot
0/11 sssss4423
I wouldn't trust any graph with a series 6th. Winisd only does parallel 6th's.
Old 11-17-2013, 07:12 PM
hornresp
Old 11-17-2013, 07:36 PM
jt_buck's Avatar
don't shoot
0/11 sssss4423
Originally Posted by korey_hofer View Post
hornresp
Still don't trust it, lol. Don't trust all the t/s either.
Old 11-17-2013, 08:11 PM
mega fatty
0/11 sssss6008
well winisd and bbp6 gave almost identical data so thats a plus.
mainly it was just what option would work best with the space i have?
12's
15's
or 18/21's
07 mazdaspeed3
rd d9 @ .5ohm
Old 11-17-2013, 08:31 PM
jt_buck's Avatar
don't shoot
0/11 sssss4423
I think you could do 3 15's if you wanted to.
Old 11-17-2013, 08:32 PM
jt_buck's Avatar
don't shoot
0/11 sssss4423
or 4 if they like a small box.
4th order vs 6th order mikeredam General Car Audio Discussion & Questions 6 06-07-2013 12:03 AM
SA8v2 4th order/6th order/Vented melverc Enclosure Discussion & Design Construction Help 0 10-07-2012 10:44 AM
