I need woofer tester 2 for Dummies! - Car Audio Classifieds!
Old 11-23-2013, 08:12 PM
Robertvon's Avatar
0/11 ssssss540
Default I need woofer tester 2 for Dummies!
I recently finished my first custom sub build and tried pulling the TSP's today and they just dont seem right I dont know if I have the test settings wrong or what .
It's a custom 15" CSP destryer
Do I pull the VAS before the Q,FS there is just so much that can be adjusted my question would be do I have some thing wrong
The QES and QTS just to is not right
Any tips or sugestions would appreciated
Old 11-23-2013, 08:31 PM
DLP customs
Guest
0/0 sssssssss
Where are you testing the driver at? Any background noise or objects close by can interfere with testing.
Old 11-23-2013, 08:44 PM
Robertvon's Avatar
0/11 ssssss540
I tested it in my living room just by myself I dont think there was any background noise that would cause interferance
I had it suspended like says and tried it sitting on a table and got almost the exact results
Old 11-23-2013, 09:03 PM
BKNIGHTS's Avatar
0/11 sssss2949
Feedback Score: 61 reviews
Did you calibrate it first?
Old 11-23-2013, 09:06 PM
BKNIGHTS's Avatar
0/11 sssss2949
And q fs first then vas. Did you do the delta mass?
Old 11-23-2013, 09:07 PM
Robertvon's Avatar
0/11 ssssss540
Yeah I even reset the configuration on it
Old 11-23-2013, 09:22 PM
BKNIGHTS's Avatar
0/11 sssss2949
I think those specs are right. Why do you think they are wrong.
Looks like you'll be running a 4th order lol
Old 11-23-2013, 09:23 PM
0/11 sssss1085
Feedback Score: 23 reviews
A lot of DIY built SPL subs end up with a high qes and a qts of over 1 without people realizing it. Let me guess - you used an aluminum wire coil and multiple spiders?
Old 11-23-2013, 09:24 PM
BKNIGHTS's Avatar
0/11 sssss2949
Let see the rest of the t/s
Old 11-23-2013, 10:45 PM
Robertvon's Avatar
0/11 ssssss540
4th is where I want to be .... just not seen very many subs with a qts and qes that high
Tags
woofer tester 2
anyone with a woofer tester beatnbronco General Car Audio Discussion & Questions 0 01-24-2013 09:18 PM
Is a Dayton woofer tester 2 any good? Robertvon General Car Audio Discussion & Questions 7 12-19-2012 07:41 AM
[SOLD] WT3 Woofer Tester sonikaccord Wiring, Electrical & Other Installation Equipment 9 12-02-2012 02:45 PM
Woofer Tester 3 OrionStang Wiring, Electrical & Other Installation Equipment 11 02-26-2012 09:48 PM
Woofer Tester in central Ohio? Nickey427 General Car Audio Discussion & Questions 2 03-03-2011 10:42 PM
