Need box design for two rf t2 15s reconed by psi..will be in 1990 camaro - Car Audio Classifieds!
Old 11-26-2013, 03:31 AM
0/11 sssssss38
Default Need box design for two rf t2 15s reconed by psi..will be in 1990 camaro
I have a delema....i need a box for a 90 camaro. has two rockford fosgate t2d415s reconed by psi..im buying a 1990 camaro saturday i dont have demensions. but i know they wont fit in the hatch so i guess im going to take out the backseat. put them in there facing the rear hatch -i think subs hit hardest facing away from you- and put an amp rack for my saz2500 in the hatch..im not good at all with a saw so my plan is to have someone on here hook me up with good designs. print them out and take it to lowes but the fiberboard and have them cut the designs out 4 me. then i can put it together -double baffled face, with support beams inside the box- also id like the box to be ported..i was thinking around 32hz..any box designs or suggestions to make this build louder would be greatly appreciated. thank u.
Old 11-26-2013, 01:31 PM
0/11 sssssss38
bump!
Old 11-26-2013, 11:21 PM
0/11 sssssss38
Bump! i need help guys! no love 4 a fellow grounp pounder?
Old 11-27-2013, 10:14 AM
0/11 sssss1868
Might help if you post it in the correct section. Also, facing forward or up is going to be pretty much it with 2 15s in a Camaro, unless you want all of the sound trapped between the box and the hatch. Try sub forward/port back. Also, do yourself a favor and cut an access panel for the fuel pump before you button everything back up. Helps a LOT on the 3rd Gen. Lastly, I'd highly consider having a cabinet shop cut your wood, as Lowe's is pretty hit and miss on getting the cuts straight.
Sent from my A200 using Tapatalk 4
The Following User Says Thank You to Fatboy501 For This Useful Post:
iamsonic (12-07-2013)
Old 12-07-2013, 04:00 PM
0/11 sssssss38
Thank u very much. got the camaro. its a beast. cant wait to shadder the hatchs glass. and how many cu ft should i do? im doing subs 4ward and port back..should i use an octo? and 32hz sound good 4 spl? or should i sacrifise the sq and do 29hz?
Old 12-07-2013, 10:08 PM
0/11 sssss1868
Honestly I'm not great with enclosures. I'd either ask for help, or fork over a few bucks for a decent design. I have no experience with T2s. 666WMD, Korey Hofer, and perfect prefect always steer me the right direction on designs.
Old 12-09-2013, 11:40 PM
0/11 sssssss38
Ok thank u i greatly appreciate the help
Old 12-10-2013, 10:26 PM
0/11 sssss1868
Glad to assist. Videos when done please... I bet it'll be brutal.
Old 12-12-2013, 08:36 PM
0/11 sssssss38
will do. im getting fiberboard for christmas lol and ill go from there. got to get new rca's cuz i accidently put a screw directly threw my rca's wen driling my amp down haha. but should be loud and will def. post vids when its done!
2 Psi 18's Box Design Help! abrosk927 Enclosure Discussion & Design Construction Help 1 05-01-2013 03:52 PM
2000 Camaro Box design... CarAudioFanatic Enclosure Discussion & Design Construction Help 6 12-11-2012 10:00 PM
need box design for psi 18 boom24 Enclosure Discussion & Design Construction Help 7 12-30-2011 02:30 PM
AQ/PSI 18" Box Design Question zone6teddy Enclosure Discussion & Design Construction Help 12 03-13-2011 01:25 AM
box design for 4 sr-15s???? CTIPPINS General Car Audio Discussion & Questions 35 03-02-2009 10:23 PM
