4th Order Design Program - Car Audio Classifieds!
Old 12-04-2013, 08:04 PM
SantaClawZ's Avatar
CEO, SounDrive Audio
0/11 ssssss374
Default 4th Order Design Program
I'm working on something similar to Torres but for 4th orders.. It works for ported boxes too, but doesn't have quite all the options to be ideal for that yet.
Progress so far after plugging in the specs for a FI Team 18 (hybrid between daily and SPL)
I need a better way to determine the optimal sealed/ported volume and port area. I've got a good way to estimate, but something more scientific would be nice.
Options right now: any size rectangle port, any size aero, any amount of aeros. Also has a quick option for a square port. Right now I have to manually set the sealed and ported volume. I've been shooting for about 45-50 sealed Fc and a 1.5-2.5:1 ratio for daily boxes.
The Following User Says Thank You to SantaClawZ For This Useful Post:
heyya (12-04-2013)
Old 12-04-2013, 08:09 PM
fireitup's Avatar
0/11 ssssss616
Feedback Score: 31 reviews
Lots of info in this thread
The 4th order thread
Old 12-04-2013, 08:10 PM
SantaClawZ's Avatar
0/11 ssssss374
Already read the entire thing, a couple of times too. I was active in it when it first went up.
Old 12-31-2013, 09:27 PM
tony30cl's Avatar
WE DEM BOYZ
0/11 sssss7527
Feedback Score: 22 reviews
im curious to see what ever happened with this
Old 01-01-2014, 12:45 PM
SantaClawZ's Avatar
0/11 ssssss374
I decided to go a different route with my build so it kind of got abandoned. I can give you access to the partially complete version if you'd like although it's not much of anything special right now. I never got around to adding end correction factor, flares, external ports, etc.. Just send me a PM with your google account if you want
Old 01-01-2014, 01:10 PM
tony30cl's Avatar
WE DEM BOYZ
0/11 sssss7527
pm me id be glad to test it out
Old 01-01-2014, 01:59 PM
tony30cl's Avatar
WE DEM BOYZ
0/11 sssss7527
so im going to post this here..
even though its just a script/spreadsheet
its alot easier than by hand. and everything is coming out as if I have done so
there are things that are going to have to be changed. other than that its great.
WTT six stickers for 4th order bp design [need design] Coast2Coast Car Audio Trader (WTT) 6 11-05-2013 11:41 PM
4th order design noknok Enclosure Discussion & Design Construction Help 29 02-04-2013 11:36 PM
Need 4th order design.... joebobclark Enclosure Discussion & Design Construction Help 0 10-27-2012 10:44 PM
4th Order Design Help Silver-N-black Enclosure Discussion & Design Construction Help 9 08-24-2011 12:23 PM
Which 4th order design? SPLEclipse Enclosure Discussion & Design Construction Help 6 05-24-2011 09:19 PM
