99 gp - Car Audio Classifieds!
Old 12-11-2013, 08:31 AM
0/11 ssssss225
Default 99 gp
what would be the best box design for my GP. 2 SQ HDS212 will be running on a SQ1200 unless I find a better deal on something 1200-1500rms 1ohm..4 door. don't plan on removing the back seat or anything. and I plan on keeping most of my trunk space (Box Wise) so trunk facing, cabin facing, ported sealed, sub uptop.. ect..??
Old 12-12-2013, 04:32 PM
0/11 ssssss225
Old 12-12-2013, 04:59 PM
B-Shot's Avatar
Bass Enhanced
0/11 sssss1733
What is the max demolitions your willing to give up? What kind of music do you listen to?
Just want to be loud or sound quality?
Old 12-13-2013, 07:01 AM
0/11 ssssss225
max dems are 34w 17h 12 deep reason being im wanting to keep it small is id actuly like to be able to get to my spare tire fairly easy lol. but ik you have to make sacarfices in this hobby. id be nice to have it tuned to 32-35hz the box in my blazer is tuned to 32HZ and it only has 2 small MTX thunder 4000s hooked up to a TIS 20 5channel amp (it was all free other then the box) wired to 2 ohms and it sounds nice, but the blazer has the room so <..> but I know the SQ hds212s need room to breath
Old 12-13-2013, 07:50 AM
djscrubb's Avatar
Captain $hit disturber
0/11 sssss2332
Make sure you can fit those dimensions through the back of the trunk opening
Old 12-13-2013, 07:52 AM
0/11 ssssss122
yeah man, double check. I had to remove seats in my gp. My box goes in through the cabin with a little bit of metal cutting. Slides right in now.
Pic from rear: h
Box on floor:
Old 12-13-2013, 07:55 AM
djscrubb's Avatar
0/11 sssss2332
Yeah I had to cut the pinch weld off on the rear deck
Old 12-13-2013, 08:01 AM
0/11 ssssss225
I have a sealed box in there right now with the same height and width
Old 12-13-2013, 08:26 AM
0/11 ssssss122
yup, cut the pinch welds a bit, Problem tolerance is so close with trunk opening that I could not have the subs in the box or it wont come out. Process to get in and out.
Old 12-13-2013, 08:28 AM
0/11 ssssss225
still dosent answer my question
