box design ? - Car Audio Classifieds!
Old 12-11-2013, 12:24 PM
0/11 ssssss200
Default box design ?
whats the difference between having a box with spearate chambers for each sub and a commom chamber? we are talking about zv4 15s?
Old 12-12-2013, 12:10 PM
0/11 ssssss200
bump
Old 12-12-2013, 12:15 PM
0/11 sssss1117
If your talking about prefab then dont get niether of them for your subs.
If you use 2 chamber, then most likely it be tuned higher and be less efficient. You have too give more info like cuft per chamber.
Old 12-12-2013, 12:23 PM
0/11 ssssss200
no prefabs. and space really isn't an issue up to 10 cu ft. i was always told that two cambers will be more efficient than one and cleaner.
Old 12-12-2013, 12:29 PM
Nope, one chamber is not only smaller but louder. It's not a huge difference but if done correctly it gai a .1's.
You only use 75% of the chamber size you would get from adding the two chambers as a subwoofer doesn't always use the entire chamber because of aerodynamic issues. The single chamber actually acts larger than it physically is because if this.
Old 12-12-2013, 12:38 PM
0/11 sssss1117
What he said. Only way i would choose 2 separate chamber over one, is if i have enough cuft for each to tune it low enough where i want and enough power, and to make a design with a port on each side so the passenger and the driver would sound the same. But one chamber is better because you dont need as much power or cuft because its more efficient
aero port box design help. willing to pay for working design Robertr Enclosure Discussion & Design Construction Help 2 04-20-2013 06:01 PM
need some box pros to design me a box...$$ fyerbyrd22 (DC) 5 09-28-2012 10:11 PM
Box design request for da box king ( 2-12" R's) da box king Box Requests 3 08-16-2010 04:23 PM
