Aero port help - Car Audio Classifieds!
Old 12-12-2013, 10:19 PM
Active Member
0/11 ssssss767
Default Aero port help
Ok, so I have a DC level 5 m2 15" that I'm building a box for and I have a 6" aero port. Box is 4 cubes after all displacements and I want to tune to 30 hertz for daily, so question is how long does the port need to be for said tuning? A few online box calculators say like 11.5 inches but I wanted to get some of your opinions. Thank for any help
Old 12-12-2013, 10:29 PM
0/11 sssss8594
Feedback Score: 55 reviews
with 4cu net INCLUDING port, 30hz is with 16.78" straight or 17.78" flared
Enclosures
Old 12-12-2013, 10:37 PM
Active Member
0/11 ssssss767
Ok so box is 4.6875 before anything. So after sub and bracing I'll have right at 4 cubes. Port is flared on both ends
Old 12-12-2013, 10:54 PM
0/11 sssss8594
is the port inside the box completely??...partially inside/partially out??...completely external?
Enclosures
Old 12-13-2013, 12:41 AM
Active Member
0/11 ssssss767
It will be inside completely. Sub up port driver side
Old 12-13-2013, 12:53 AM
0/11 sssss8594
the tuning is going to be directly related to how much space it takes up inside the box, accounting for the cu ft inside and the displacement of the aero...BUT to answer your question, the port need to be 17.78" flared when the box is 4cu net
Enclosures
The Following User Says Thank You to fyerbyrd22 For This Useful Post:
burtow2011 (12-13-2013)
aero port box for 4 sa-8's, too much port? Dbmonster (Sundown Audio) 4 08-11-2011 02:08 AM
finding 10" aero port, port calculation help darkkon General Car Audio Discussion & Questions 6 07-24-2011 07:26 PM
aero-port vs. slot port? thumper21 General Car Audio Discussion & Questions 23 03-22-2011 11:12 AM
