Im a trunk guy, so this is different.... - Car Audio Classifieds!
Old 12-19-2013, 01:46 PM
Rocken JBL's Avatar
0/11 ssssss941
Feedback Score: 21 reviews
Default Im a trunk guy, so this is different....
I have a buddy wanting to do a build in a 99 tahoe with 1 18" nightshade v1. I dont know how to start with the box because I do trunk builds normally... I was think sub up port back? Slot or Aeros? I am unsure I need to be guided in the right area, from there I will be good. If anyone has any pics that will be helpful as well.
Thanks in advance
Owner-The Dog Pound Car Audio Club, Owensboro
-Team Sundown Audio
-FCBC 200 MOD Champion 2012
-Runner up 200 SD Champion 2011/2010
-MECA AS2 Kentucky state points Champ in 2010
Old 12-19-2013, 01:56 PM
e46inperrycounty's Avatar
SPL Farms
0/11 sssss5706
Go through the build logs and the Tahoe/Suburban threads and see what others have done for single 18's. Aeros take up less space and are more efficient use of port area. I have had both slot and aero (round) ports and have had better results with the round port so far.
2 Ampere 3.0v2 18's
BC5500 at half ohm
Mark Antony gs380.4
Anarchy 6.5s
AB sq6b's
Team SPL Farms
Old 12-19-2013, 02:16 PM
1ndatrunk's Avatar
Stinkin Linkin
0/11 sssss2172
Feedback Score: 30 reviews
Unless you're going to make the box sit close to the rear doors for the port to reflect off of, then I'd do sub up/port to the side. 4.8cuft net, depending on power and music preference. Tuning is up to you also
Audiopipe Nutthuggery at its finest
Trunk build... rear deck vs. sealed trunk regizzle General Car Audio Discussion & Questions 9 04-12-2013 05:09 PM
Who Sits In The Trunk When They Drive? Acoustic Treatments To Block Off Trunk? 05LGT Sound Quality Area 25 08-12-2012 09:04 PM
Trunk 0-1000w Class RUN....LOUDEST TRUNK EVER Skip01 Car Audio Videos 270 04-30-2012 09:54 PM
4 door trunk car - cant use trunk ... brian84corvette Enclosure Discussion & Design Construction Help 23 10-13-2010 09:24 PM
Trunk KcRidin09 Enclosure Discussion & Design Construction Help 13 05-26-2010 02:19 PM
