powerwheels box tunning - Car Audio Classifieds!
Old 12-23-2013, 02:02 PM
noknok's Avatar
0/11 sssss1521
Default powerwheels box tunning
ok guys i have a lil problem. im trying to get my sons powerwheels to peak a lil higher. rightnow it does a 141.2 in the kick @31hz i would like to tune it a lil higher in the 39-42hz range. box is 12 1/2 x 22 1/2 x 10 3/4 only problem is port, its a 4' port with flares on both ends. im stuck at 20'' of port since its ran thew the car. if i shrink the box a lil would that be a problem with port noise? or would it hurt his scores?
HEEELPPP!!
Old 12-23-2013, 06:09 PM
B-Shot's Avatar
Bass Enhanced
0/11 sssss1733
I dont think port noise would be an issue, I use cheap caulk to attach my blocks of wood in the bottom of the box to shrink the volume when testing, if it works out good I will screw it in permanent or build the proper size box
Old 12-23-2013, 06:52 PM
graham's Avatar
Tinder Douchebag
0/11 sssss7122
Why would you want the peak higher? -edit- that high anyway
team graham
Old 12-23-2013, 07:30 PM
noknok's Avatar
0/11 sssss1521
31hz is too low for that car imo..i built the car to do some numbers on the termlab.
the box . i only have 1.24 cf net subs are inverted.. for a pair on 8s. im stuck with that only option is to shrink the box. but idk if the 4'' port would be too big for a box smaller then what i have.
Old 12-23-2013, 07:37 PM
tony30cl's Avatar
WE DEM BOYZ
0/11 sssss7527
Feedback Score: 22 reviews
i would just toss a large 5'' port in it and start testing.
or tune in the 50s .
i mean its plastic. its res should be pretty low
Old 12-23-2013, 07:45 PM
mega fatty
0/11 sssss6008
I thought I saw some power wheels peak around mid 60's
Maybe I'm totally off but I thought I saw that in some thread.
07 mazdaspeed3
rd d9 @ .5ohm
Old 12-23-2013, 07:47 PM
tony30cl's Avatar
WE DEM BOYZ
0/11 sssss7527
metal plates in the floor help
Old 12-23-2013, 07:56 PM
noknok's Avatar
0/11 sssss1521
My only option with this setup is shrinking the box.. port barley fit and its glued together. I don't wany to tune that high either. Leave some room for some music. He shows it off too..
Powerwheels HPI motors 3rdshiftdiscretion Miscellaneous Stuff For Sale 6 09-07-2011 09:35 PM
3rdshift's Powerwheels build. 3rdshiftdiscretion Build Logs 24 08-09-2011 08:22 PM
box tunning! juggheadtattoos General Car Audio Discussion & Questions 2 01-29-2011 11:12 PM
tunning sheldonfromltown General Car Audio Discussion & Questions 7 02-16-2010 03:31 PM
Customer's Powerwheels R/T Pimp Build Logs 10 12-08-2009 02:02 AM
