Can someone confirm this design for me? - Car Audio Classifieds!
Old 12-28-2013, 02:38 PM
doug118's Avatar
0/11 sssss4674
Default Can someone confirm this design for me?
This is for a single 18" SP4. Sub up, port back on passanger side. Should I do the port on the bottom? I'm not going for numbers. Just something temporary
Old 12-28-2013, 03:09 PM
GiGLZ's Avatar
0/11 ssssss514
Aim for about 12-14 sq inches of port area per foot and 60-90 on port area.
Do you really think you need 1.5" thickness all around?
Team Western Insanity
Vancouver, Canada
Old 12-28-2013, 03:12 PM
doug118's Avatar
0/11 sssss4674
Probably not but I don't want to do much internal bracing
Old 12-28-2013, 03:56 PM
doug118's Avatar
0/11 sssss4674
made a few changes. Which one looks better?
Old 12-28-2013, 04:30 PM
GiGLZ's Avatar
0/11 ssssss514
Bottom one looks better but need more port area per ft. Shrink the box down to about 6.5 cubes net
Vancouver, Canada
Old 12-28-2013, 08:08 PM
666WMD's Avatar
No idea what I'm doing
0/11 sssss1307
Unless you're doing a port that sits away from any of the walls, you need to enter the number of port walls as it will change the volume and tuning. See the help menu for how they are laid out.
Old 12-30-2013, 12:59 AM
doug118's Avatar
0/11 sssss4674
Built the last one, but added the common walls and shortened the port to 17". Not sure if something is wrong or I'm just expecting too much from it. I went from a pair of sa15's in a 4th order to a single 18. Some songs are actually louder than the 4th but most of them lack the output I expected
Old 12-30-2013, 01:17 AM
BigBen's Avatar
0/11 sssss3006
Feedback Score: 24 reviews
If you didn't change anything from the calculator the box isn't tuned right. You didn't account for number of walls the port touches. Makes a HUGE difference. And the port is really small. 14-16" per cube will be much louder. Also if your port.is just L shaped then the sub would be better more towards the port and away from the opening of the port. It's not letting the air compress inside it.
Sent from my C6906 using Tapatalk
Old 12-30-2013, 01:57 AM
0/11 sssss1117
People never take into account that the port will cause box rise if not properly design for said vehicle and subs. Your probably louder on the lower end where your box is tuned at, but lack the higher frequency because of box rise.
In my opinion is to get a proper box design by Pete pwkdesigns.com but if you go to anyone else its either a hit or a miss like your box.
Old 12-30-2013, 02:10 AM
Todd Dupler's Avatar
Team SPL Farms
0/11 sssss5000
Build a new box. Sub up port firing into driver side. Needs more port area too. I generally try to go 12-15 sq in per cube for a slot and 9-12 for a tube port.
01 Volkswagen Golf 2 door
Kenwood ddx470
Notice About Midwest Regionals CONFIRM SEPT 26th Radio Dr. bumpin buick General Car Audio Discussion & Questions 65 09-26-2010 12:52 PM
Confirm for me my friends..... PIC Vaginatarian General Car Audio Discussion & Questions 4 03-14-2010 08:22 AM
Confirm my box tune..?? Vaginatarian General Car Audio Discussion & Questions 0 01-25-2010 10:21 PM
Can anyone confirm this? silvercookie General Car Audio Discussion & Questions 11 11-19-2009 02:13 PM
Building first box with aeros, can someone confirm length W O T Enclosure Discussion & Design Construction Help 15 09-29-2009 02:06 PM
