2 sa 12s aeroported . - Car Audio Classifieds!
Old 01-04-2014, 05:34 PM
0/11 sssssss15
Default 2 sa 12s aeroported .
Hey guys kinda new to this forum. I'm looking for some help designing a enclosure for 2 sa 12s. I would like to have the 2 SUVs and port facing into the cabin out of my trunk. I would like to go aeroported. I have 36.75 "w 15.5"h 22"d to work with. I'll be running them on a ab vfl4480.1 @1ohm. Thanks in advance to anyone who can help me out.
Sent from my Galaxy Nexus using Tapatalk
Old 01-07-2014, 03:42 AM
0/11 ssssss102
id help but unfortunately my mac computer won't allow me to run the torres box calculator. however, depending on what you're aiming for with the setup i can lend you some tips in how to design one yourself.
Old 01-07-2014, 09:55 AM
0/11 sssssss15
Well, I'm aiming for a loud and as clean as possible to be very honest. Ive read a lot of forums with people saying they've had better results and cleaner output with aeroports as apposed to slot ports. The box I am using right now is slot ported and is exactly the dimensions I listed in my first post above. Its tuned to 34hrz. It gets loud but I'd like to tune lower I think.maybe 30hrz.
Old 01-07-2014, 12:39 PM
0/11 ssssss102
Not sure what kind of vehicle you have but sounds like you're looking to do something like this with an aero. my sa12s beatin - YouTube
Old 01-07-2014, 12:42 PM
0/11 sssssss15
I have a 2012 ford fusion. And yes that's exactly what I'm trying to do. Real nice set up by the way.
Old 01-07-2014, 12:49 PM
0/11 ssssss102
Thanks, idk what others would recommend but i built my box so it completely plugged the hole to my trunk. the inner trunk walls fit snug around the box, helped with bracing and sealing from the trunk. at first i had hardly any trunk flex but over time shit just got rattly. Granted i didn't go above and beyond to keep it sealed but that box was 3.2 cubes at 33hz. And for the most part these little sa12s sounded pretty good imo.
Old 01-07-2014, 01:03 PM
0/11 sssssss15
The box I'm using now looks a lot like the one in your video. Its 4.3 cubes tuned to 34hrz. It gets pretty low but I'm sure I could get louder. I thought about building it big enough to seal off the trunk but it would have to be 43" wide. And I had enough trouble getting the one I have now in the trunk and its only 36.75" wide. I would post a pic but I'm not sure how.
Old 01-11-2014, 07:40 PM
briankeith1007's Avatar
0/11 ssssss374
Go to www.the12volt.com,it has everything you need to build
A awesome box.
Old 01-11-2014, 07:45 PM
e46inperrycounty's Avatar
SPL Farms
0/11 sssss5706
Build inside the trunk... my box is huge and tuned to 23hz... it gets low...lol
2 Ampere 3.0v2 18's
BC5500 at half ohm
Mark Antony gs380.4
Anarchy 6.5s
AB sq6b's
Team SPL Farms
Old 01-11-2014, 07:52 PM
0/11 sssssss15
Do you mind me asking the dimensions of your box? Are you using sa12s as well?
zv3 12s or tantric hdd 12s on a aq3500 macandcheese General Car Audio Discussion & Questions 5 09-04-2013 01:34 PM
DAD kmh 12s or Skar vvx 12s walkertxranger General Car Audio Discussion & Questions 0 03-10-2013 05:36 PM
System Swap from 6 12s to 2 12s...STOP MOTION ACTION Skip01 Car Audio Videos 8 01-02-2013 12:44 AM
Audioque hdc3 12s or MTX 9500 12s??? 1993burban General Car Audio Discussion & Questions 18 12-08-2011 01:56 AM
2 mojo 12s ported or 4 cvr 12s sealed? audio man General Car Audio Discussion & Questions 5 08-11-2011 12:01 AM
