Why no hair trick? - Car Audio Classifieds!
Old 01-05-2014, 08:09 AM
Beatdown337's Avatar
0/11 sssss1535
Default Why no hair trick?
Tell me if you guys think I'm tripping. We have 2 psi platform 3 18's on a crescendo 5500 at 1 ohm. The box is 14 cu ft after port and woofer displacements with 4 6 inch aeros tuned to 32. This is in the cargo area of a Tahoe.
It's loud as f***. I mean seriously. To the point where 2 experienced bass heads like my homeboy and I have to give it props. These woofers are brand new from psi, just put them in yesterday. Everything plays pretty flat and I'm suprised and pleased with the bandwidth. Only thing is although there's plenty of air movement, it's not enough for a hair trick. Why is that? Not enough power? Port area? I thought sure we would be able to pull this off. Any help or input appreciated brohams.
Discuss
Old 01-05-2014, 08:14 AM
Veteran Member
0/11 sssss3359
that is pretty odd. my little brothers could do a hairtrick from cargo area on 2 hdc4 15s and a saz4500 @1 ohm with 3 6" aeros. Not a nasty hairtrick by anymeans but it could definitely do one
Old 01-05-2014, 08:47 AM
doug118's Avatar
0/11 sssss4674
Is your back window glued shut? You could be losing a ton of pressure
Old 01-05-2014, 08:56 AM
0/11 sssss1117
Subs up port back? Im sure you can get it moving if you play some song tuned to 26hz or so at full tilt.
Old 01-05-2014, 09:01 AM
0/11 sssss1535
Man I'm really not sure at all. It doesn't make much sense to me. Ill get some chick to stick her head in and try it out today.
Old 01-05-2014, 09:02 AM
0/11 sssss1535
Nah it's not glued. U think it would make that much of a difference?
Old 01-05-2014, 09:04 AM
Veteran Member
0/11 sssss3359
do it. and post vids!
Old 01-05-2014, 09:06 AM
dirt101's Avatar
0/11 ssssss956
Brand new woofers is my guess. Give them a week or two to loosen up
Old 01-05-2014, 09:11 AM
0/11 sssss1943
Post pics of the box as it sits in the tahoe.
Old 01-05-2014, 09:16 AM
0/11 sssss1535
Yea subs up and port back. Weird part is I got a port plug to block one of the aeros which would drop the tuning to 28 thinking the lower tuning would give the hair trick I was looking for. But when I put it in, it just simply wasn't as loud. No exaggerated low end or anything. The caveat here is that I bought a 6 inch plug, but it doesn't seem to work so well with the flare. I'm guessing maybe it's just restricting air more than blocking the port? whole situation is weird.
Hair trick!!!!!!!!!!!!!! vince79vette General Car Audio Discussion & Questions 3 10-21-2012 10:00 AM
Afro man hair trick, dual black girl hair trick, and non stop demo's!!!! basebalz13 Car Audio Videos 28 10-14-2012 02:15 PM
little hair trick fox_racin4 Car Audio Videos 9 10-03-2012 07:41 PM
hair trick anyone? stretch Car Audio Videos 3 03-10-2012 11:25 PM
Best hair trick !!! r1 banshee Car Audio Videos 21 11-15-2011 06:06 PM
