Calling all 6th order experts - Car Audio Classifieds!
Old 01-20-2014, 04:48 PM
0/11 ssssss256
Default Calling all 6th order experts
I am building a demo/comp vehicle. I want to do a nasty 6th order with 6-8 15s or 18s. Two questions.
1. Parallel or series? What are the differences besides the obvious.
2. What do you tune the two chambers to?
Old 01-20-2014, 05:16 PM
jt_buck's Avatar
don't shoot
0/11 sssss4423
Series, a good starting point is 30/60.
Old 01-20-2014, 05:35 PM
e46inperrycounty's Avatar
SPL Farms
0/11 sssss5706
For a quasi 6th you will need a shyte load of space. Less is more as far as cone area here. For that many subs ~24 cubes for your rear chamber... about twice that for the front chamber... if you have 70 cubes gross to work with then game on bro... if not, might be further ahead to do a proper 4th or big ported wall
2 Ampere 3.0v2 18's
BC5500 at half ohm
Mark Antony gs380.4
Anarchy 6.5s
AB sq6b's
Team SPL Farms
Old 01-20-2014, 05:36 PM
0/11 ssssss256
Going to be in a astro van or suburban. Plenty of room
Old 01-20-2014, 05:43 PM
0/11 sssss4519
Parallel 60/30 has always done very well for me.
To find sealed resonance
resolve Vas/28.32 =
result of that +1
square root that result
Old 01-20-2014, 05:45 PM
0/11 ssssss256
I was leaning towards parallel both ports driver side.
Old 01-20-2014, 05:49 PM
0/11 sssss4519
I had my ports top and bottom and loved it.
resolve Vas/28.32 =
result of that +1
Old 01-20-2014, 05:51 PM
0/11 ssssss256
Looking for maximum load at the passenger side. So I was thinking driver side port but I'm open to ideas. Never built a 6th
SPL Farms
0/11 sssss5706
Already have your drivers? T/S parameters of the subs you are considering?
2 Ampere 3.0v2 18's
BC5500 at half ohm
Mark Antony gs380.4
Anarchy 6.5s
AB sq6b's
Team SPL Farms
Old 01-20-2014, 05:53 PM
0/11 ssssss256
No drivers yet. Most likely will be built at fi to whatever specs I'm looking for. Lucky enough to live in Vegas and have a in at fi.
4th order experts guidance needed doug118 General Car Audio Discussion & Questions 24 03-09-2012 02:20 PM
