4th Order Removable Panel Help??? - Car Audio Classifieds!
Old 01-21-2014, 02:27 PM
0/11 ssssss888
Default 4th Order Removable Panel Help???
Hello all, I am currently building a box for a customer and I'm having second thoughts on my build design for the removable panel. Just curious if you all have pics of your removable panels so I could weigh my options. Here is the box (below) and the front will have 2, .5" acrylic panels so you can see the SA 8" V.2's inside. You can kind of see on the design but I was going to use 2 1/2" boards and laminate them after routing out a 3/4" lip on the top on so you can remove the acrylic. I am just curious if there are other/better options, Thanks!
File Type: jpg 1512194_10202890170754815_1040451516_o.jpg (55.1 KB, 56 views)
Team Lethal Beatz
Alpine 9886
2 st350's, 2 Eminence alpha 10's
MB Quart DSC2150
MB Quart DSC4125
4 RD sonances
2 IA 20.1's Strapped at 1 ohm
4 Deka 9a31's
220A alt
Wall tuned at 29 hz
Old 01-21-2014, 07:52 PM
0/11 ssssss888
I was thinking along the lines of threaded inserts epoxied in. But I have a sneaky suspicion that they wont hold.
Team Lethal Beatz
Alpine 9886
MB Quart DSC2150
MB Quart DSC4125
4 RD sonances
4 Deka 9a31's
220A alt
Wall tuned at 29 hz
Old 01-21-2014, 08:53 PM
vince79vette's Avatar
0/11 sssss2011
Just use weather stripping from lowes and screw ever few inch. I did a 6th order with a sa 8 and 0 leaks
0/11 sssss2011
I also used .5 plexi too
Old 01-22-2014, 02:04 PM
0/11 ssssss888
Nice box! I can't do it that way because the acrylic is already cut to size and they are going to be mounted in mdf or plywood thats removable. But looks nice, Thanks for the input
Team Lethal Beatz
Alpine 9886
MB Quart DSC2150
MB Quart DSC4125
4 RD sonances
4 Deka 9a31's
220A alt
Wall tuned at 29 hz
Old 01-22-2014, 02:15 PM
xnewbx's Avatar
0/11 ssssss985
Weather stripping is excellent for removable panels.
Old 01-22-2014, 02:40 PM
0/11 sssss2011
Thanks man. So where is the plexi going I am a little lost on where u are putting it
Contributor
0/11 sssss1662
Vince, that is sexy.
Old 01-22-2014, 03:17 PM
Silver-N-black's Avatar
0/11 sssss3544
When you guys say weather stripping would this work Shop Frost King 3/8-in x 17-ft Grey Foam Door Weatherstrip at Lowes.com
or http://www.lowes.com/pd_297209-81-43...ing&facetInfo=
Old 01-22-2014, 03:28 PM
xnewbx's Avatar
0/11 ssssss985
I use the first link, the grey foam
Access panel for 4th order arejayeye General Car Audio Discussion & Questions 10 10-18-2012 01:18 AM
