Trunk wall or no? - Car Audio Classifieds!
Old 01-27-2014, 08:42 PM
KickinBlazer's Avatar
0/11 sssss1122
Default Trunk wall or no?
would there be a very big diffrence between walling off at the trunk facing forward or a slide in box rear facing?.....anyone tested or done this?....going from a pair of 10's to a single 15 ......iv got experience with building so build would be quality....
if its to loud your to old!
Old 01-27-2014, 08:45 PM
0/11 ssssss209
well it would prolly be better to wall. i had 2 HDC312'S with a trunk wall in my sebring i had got pretty loud and i had no trunk rattle. i kind of did it half azz but basically i just used spray foam to fill the gaps between the sides of the box and trunk wall. the box i made fit in pretty tite so i did not have to use much. i also used it to fill any other holes that would allow air to move between the trunk and cabin.
i copied it from what i said on ROE lol
96 jeep grand cherokee 4.0l
Pioneer DEH-P7200HD
Stetsom 10kd, stetsom 1k6es2, stetsom vs400.4
4 mp-8's
2 skar vx4-st super tweeters
Old 01-27-2014, 08:55 PM
doug118's Avatar
0/11 sssss4674
I personally liked my rear firing setup better.
Old 01-27-2014, 09:11 PM
0/11 ssssss386
What is a trunk wall? I never seen a wall that was 17 inch high LOL.
But a properly sealed off front firing box sounds great and can do numbers.
2013 and 2011 Midwest SPL Extreme Trunk Champ
94 Honda Accord
Two DD 9915 SC front firing out of the trunk
2 DD M4a's
Old 01-27-2014, 09:14 PM
0/11 sssss1122
exactly what i said on ROE to...lol...not really looking for numbers manily SQL
i am not worried about trunk rattles 2 layers of stinger roadkill and felt stuffed in voids.....my only problem is to run the trunk wall would take me relocating the 6x9's (in factory locations), battery, amp and rerunning the 1/0.....would it be worth all that just to wall....or just build a slide in box, relocate the 6x9's and add a little more deadening to the rear deck?
Old 01-27-2014, 09:53 PM
eddiemoua94's Avatar
0/11 ssssss183
ive recently just sealed off my trunk. i love the sound so much more than when i had it in the trunk. plays pretty low. 28hz full tilt and i dont have to worry about bottoming out. every set up is different, and every car is different. prefer the seal off cuz of less rattles. even if you have your trunk lid deaden its actuallly the matter of can you still hear the rattle? saz3k on 2 treo ssx in the trunk rattle so much i hatted it. broke my spoilter bolts and worst part is you can hear the rattles while playing bass. sealed off i get little rattle from the trunk lid that it doesnt bother me. and since i cant hear it rattle im happy with it. btw my trunk like is not deadned at all. bad cuz thats probably why it rattled so much but good cuz even without deadener sealed off it doesnt rattle too much. and as for all the work youre gonna have to do.. thats up to you lol. do you want too? or do you not want too? haha but honestly it was worth sealing off. havent gotten numbers yet but without seal off i was doing 143.3 at 31hz. sealed off i should be doing 145 at 31hz but i havent metered yet.
Old 01-27-2014, 10:14 PM
e46inperrycounty's Avatar
SPL Farms
0/11 sssss5706
Sealing mine off was the best thing I ever did
2 Ampere 3.0v2 18's
BC5500 at half ohm
Mark Antony gs380.4
Anarchy 6.5s
AB sq6b's
Team SPL Farms
Old 01-27-2014, 10:49 PM
jhg33k's Avatar
n00b looking to learn...
0/11 sssss1531
Feedback Score: 31 reviews
I vote forward and sealed from my own experiences as well. Tested many boxes in my car and that's what I still use to this day.
One thing about sealing off though that a lot of people miss is it's not just sealing around the box. Rear deck, b-pillars, c-pillars (sides of rear window), inside of door sills, top channels above door openings, etc. All those places give pressure channels back into the trunk.
|2011 Toyota Carolla S |2 Mmats HD4000.1's | Pair DC XL 12's w/AR cones | Average headrest score out of the trunk...will update after world finals
Old 01-27-2014, 11:16 PM
slowpoke's Avatar
newbie forever
0/11 sssss1160
i just built a sealed off box to the cab in my 90 tbird for the first time. best thing i ever did. 4 AB 8's and its way louder than i would have ever expected.
150db loud redneck
Old 01-27-2014, 11:18 PM
Twitney181's Avatar
0/11 ssssss591
I had awesome success with my 2 12's sealed off. And even more success with my single fi sp4 15 sealed off. Like said above tho, it's TONS of work to actually get it sealed off 100%.
Here's a little vid of it Sp4 15 windshield flex - YouTube.
2nd half of the vid is better haha fi sp4 on a dd m3a.
Chrysler 300 trunk wall off Burbarry Build Logs 43 04-12-2015 06:32 PM
PWK design for trunk wall Burkem_10 Car Audio Product Reviews 22 08-21-2013 10:41 AM
Sealing off trunk wall jd93kid General Car Audio Discussion & Questions 21 06-24-2013 11:48 AM
trunk wall? smokenyall General Car Audio Discussion & Questions 31 04-10-2012 05:32 PM
Need Help With A Trunk Wall/Box Design. partyboy6686 Enclosure Discussion & Design Construction Help 2 09-26-2010 10:47 PM
