2 hdc4 15 in a 4th order - Car Audio Classifieds!
Old 01-29-2014, 09:32 PM
0/11 ssssss405
Default 2 hdc4 15 in a 4th order
ok so i started with 2 hdc3 motors with dc audio level 5 cones and baskets in around 11 to 12 cubes ported with 2 6 inch aero all firing back on a soundigital 8k in my trunk of 96 impala. but i ordered 2 new hdc4 15s instead of using the hdc3 ones. they do alright in the ported box. i thinking of doin them in a 4 th order. i got around 16 cubes if i go 4th. i was thinking either 4 sealed into 12 ported or 5 sealed into 11 ported. as far as the port thou i dont really know what to do there.. i will be porting it throu the rear deck. i ve built boxes for years and this is my first 4 th order. i would appreciate some help/ advice for this one...thanks in advance
Old 01-29-2014, 09:37 PM
0/11 ssssss405
here are the specs
Model HDC415-D1-A
Woofer Size 15"
Fs 39.03 Hz
Vas 31.140 ltrs (1.100 cubic feet)
Xmax 40mm
Qms 5.204
Qes 0.373
Qts 0.348
Motor Weight
65lbs
Coil Diameter 4.0"
Coil Length 2.14"
Useable Throw 2.75"
RMS Power 2000 W
Peak Power 6000 W
Mounting Depth 8 1/8"
Cutout Diameter
13 3/4"
Model HDC415-D1-A
Old 01-29-2014, 10:46 PM
0/11 sssss2649
4th order seems like the way to go in your trunk. I'd go with 4 sealed and 12 ported.
Check out the 4th order thread if you haven't already.
Old 01-29-2014, 11:30 PM
e46inperrycounty's Avatar
SPL Farms
0/11 sssss5706
With the QTS being that low the subs will work better in a standard ported enclosure or a 6th rather than a 4th. You want a QTS .5 or higher for an efficient 4th order sub.
2 Ampere 3.0v2 18's
BC5500 at half ohm
Mark Antony gs380.4
Anarchy 6.5s
AB sq6b's
Team SPL Farms
Old 01-29-2014, 11:36 PM
Veteran Member
0/11 sssss3359
So zv3's arent a good 4th order sub? Lol. Jared was doing a 160+ with 4 15's in a 4th with th zv3's. Mine is doing work as well. Qts .427
Old 01-29-2014, 11:39 PM
SPL Farms
0/11 sssss5706
Didn't say it wouldn't work, said it wouldn't be as efficient... a proper 4th needs very little power to get a ton of output... Steve Mick's buddy sobel's astro gets into the 50's on 2200 watts... Then again that is one of the most efficient 4ths I have seen as far as design and subs.
2 Ampere 3.0v2 18's
BC5500 at half ohm
Mark Antony gs380.4
Anarchy 6.5s
AB sq6b's
Team SPL Farms
Old 01-29-2014, 11:43 PM
Veteran Member
0/11 sssss3359
Im messin with ya. But ya those efficient 4ths are mind blowing to me. Mystery. And those hdc4's have a very low qts
Old 01-29-2014, 11:45 PM
Veteran Member
0/11 sssss3359
They definitely get down and dirty. My brother had a set of 15"s in his cherokee that loved tons of power and played very low
Old 01-29-2014, 11:48 PM
SPL Farms
0/11 sssss5706
Lol, I have been picking steves brain as much as I can about the 4ths he has done and reading a ton of stuff from HACKMUNCH here lately... Those guys pull amazing numbers on low power... yeah 9 18's in an astro should be loud, but on 2200 watts Its still foreign to me but HACK swears it is all about using the right sub for the job in the first place so you aren't fighting an inherent lack of efficiency by stuffing a sub that thrives in ported enclosures into a sealed enclosure.
2 Ampere 3.0v2 18's
BC5500 at half ohm
Mark Antony gs380.4
Anarchy 6.5s
AB sq6b's
Team SPL Farms
Old 01-29-2014, 11:50 PM
SPL Farms
0/11 sssss5706
They are both all about tuning the ported side to sealed resonance and using an impedance sweep before the loading wall goes in to find actual sealed resonance
2 Ampere 3.0v2 18's
BC5500 at half ohm
Mark Antony gs380.4
Anarchy 6.5s
AB sq6b's
Team SPL Farms
SA8v2 4th order/6th order/Vented melverc Enclosure Discussion & Design Construction Help 0 10-07-2012 10:44 AM
4th Order vs. 6th Order? younggunzbass01 Enclosure Discussion & Design Construction Help 18 05-24-2011 05:34 PM
