Port Assitance - Car Audio Classifieds!
Old 02-03-2014, 10:21 PM
0/11 ssssss857
Default Port Assitance
Building a box for 2 sundown x12s. Specs are:
Width 36"
Height 16.5"
Depth 20"
I am going to use 2 4" psp ports. Cant figure out how long to make them to tune around 37hz.
Torres says ~5.5" but psp site says flared length is 7.9689"
Someone please help me out here so i can get the right tuning freq.
Old 02-03-2014, 10:25 PM
B-Shot's Avatar
Bass Enhanced
0/11 sssss1733
Psp site does not subtract displacement of port if that helps
Old 02-03-2014, 10:31 PM
0/11 ssssss857
Ok so go with torres 5.5"? Now is that 5.5" from end of flare to end of flare or the length of the center piece?
Old 02-03-2014, 10:36 PM
e46inperrycounty's Avatar
SPL Farms
0/11 sssss5706
And 25 inches of port area is not nearly enough... especially if you are trying to tune in the upper 30's...
2 Ampere 3.0v2 18's
BC5500 at half ohm
Mark Antony gs380.4
Anarchy 6.5s
AB sq6b's
Team SPL Farms
Old 02-03-2014, 10:39 PM
SPL Farms
0/11 sssss5706
The type x's in the current sized enclosure will need 8" diameter port... 2 4" ports will give you about 4-5inches of port per cube. You need to be about double that.
2 Ampere 3.0v2 18's
BC5500 at half ohm
Mark Antony gs380.4
Anarchy 6.5s
AB sq6b's
Team SPL Farms
Old 02-03-2014, 10:42 PM
SPL Farms
0/11 sssss5706
Around 15" length of 8" diameter port after displacement should get you around 37hz tune
2 Ampere 3.0v2 18's
BC5500 at half ohm
Mark Antony gs380.4
Anarchy 6.5s
AB sq6b's
Team SPL Farms
Old 02-03-2014, 10:43 PM
0/11 ssssss857
should i shrink box down a bit for the x?
Old 02-03-2014, 10:44 PM
SPL Farms
0/11 sssss5706
Nah, I'd just stick with box size you have and let them breathe by opening up the port area... having too little port is like trying to scream with your mouth shut...
2 Ampere 3.0v2 18's
BC5500 at half ohm
Mark Antony gs380.4
Anarchy 6.5s
AB sq6b's
Team SPL Farms
Old 02-03-2014, 10:45 PM
SPL Farms
0/11 sssss5706
Edited^
2 Ampere 3.0v2 18's
BC5500 at half ohm
Mark Antony gs380.4
Anarchy 6.5s
AB sq6b's
Team SPL Farms
Old 02-03-2014, 10:51 PM
0/11 ssssss857
where can i find an 8" port that isnt stupid expensive. I dont mind spending a little cash, just not an arm and leg
thanks guys
Cartunz 3X show 6-24-2012 $500 for loudest non Port or Super Port score bdufner Competition Corner 2 06-16-2012 08:29 AM
SPL box... Slot port? Port Tube? Kerf? CousinVin Enclosure Discussion & Design Construction Help 13 07-21-2011 02:41 PM
*PICS* Dual 10" Aero's. sub up/port up VS sub up/port forward Magnet General Car Audio Discussion & Questions 16 06-13-2011 03:24 PM
~143^2 Aero Port vs 235^2 Slot Port for 21 net cube enclosure VOPA1 Enclosure Discussion & Design Construction Help 6 12-02-2010 05:03 PM
Help with a BP, slot port or square port for 2nd row 4th order bandpass wall 46panel General Car Audio Discussion & Questions 7 08-24-2010 09:32 PM
