Can I change this 4.0 f^3 single 15" enclosure into a single 1.5-2.5 12" enclosure? - Car Audio Classifieds!
Old 02-05-2014, 05:24 PM
graham's Avatar
Tinder Douchebag
0/11 sssss7122
Default Can I change this 4.0 f^3 single 15" enclosure into a single 1.5-2.5 12" enclosure?
I have this single 15" 4.0 f^3 box and I'm wondering if I can cut it in half or so and switch it to sub up/port back.
For a DC lvl 4 m2 12"
I was going to just take it apart and use the pieces for scrap to use for testing my box building skills, but I wanted to ask this first, as it seemed possible and easier.
team graham
Old 02-06-2014, 12:43 AM
graham's Avatar
Tinder Douchebag
0/11 sssss7122
bump
any box calculators that run on linux?
team graham
Old 02-07-2014, 10:02 PM
graham's Avatar
Tinder Douchebag
0/11 sssss7122
Free red 3 wire volt meter *shipped* to your door for help resulting in a successful conversion
team graham
Old 02-07-2014, 10:06 PM
e46inperrycounty's Avatar
SPL Farms
0/11 sssss5706
It looks pretty hoe bagged already man... I would just disassemble it and reuse the pieces to build a proper single 12' enclosure.
2 Ampere 3.0v2 18's
BC5500 at half ohm
Mark Antony gs380.4
Anarchy 6.5s
AB sq6b's
Team SPL Farms
Old 02-12-2014, 08:30 AM
graham's Avatar
Tinder Douchebag
0/11 sssss7122
Alright, I guess I will. Know of any basic designs for this sub?
team graham
Old 02-12-2014, 06:51 PM
briankeith1007's Avatar
0/11 ssssss374
Default Start here.
www.the12volt.com,if you need help with this site,just hit me up.
Old 02-12-2014, 06:56 PM
0/11 ssssss374
Default Or
Just buy one more 12 and cut one more 12 inch cutout for that new sub.
Old 02-18-2014, 09:19 AM
testtones812's Avatar
0/11 ssssss109
more often then not, its just as much work to change that enclosure as it is to build a new one. If you want to use that one, DC recommends 1.5ft^3, so you could try and cut that one down to that size (+port). You wont be able to use your current port area though. that would be much too large in a 1.5 ft^3 enclosure and result in a required port length of 71" to get about a 35 Hz tuning. Without knowing more details as far as preference and power.... I would aim for around the 20in^2 area for port. That would give you a required port length of around 25.5"
Single 18" enclosure stylez12321 Wiring, Electrical & Other Installation Equipment 20 03-21-2012 07:32 PM
Single 18" Enclosure madridlv70duece Wiring, Electrical & Other Installation Equipment 9 02-27-2011 07:40 AM
Single 12" Sealed Enclosure Brock592 Wiring, Electrical & Other Installation Equipment 0 11-09-2010 08:07 PM
WTB 15" single enclosure Rd4me Wanting to Buy (WTB) 9 11-30-2009 03:27 PM
Enclosure Build for single 15" Pioneer~Saturn Build Logs 3 08-09-2009 10:46 PM
