Building box in sealed off trunk question - Car Audio Classifieds!
Old 02-08-2014, 07:57 PM
0/11 sssssss22
Default Building box in sealed off trunk question
I'm wanting to try something new for my set up. Plus my trunk rattle is extremely bad. So next week I'm going to attempt to build a 8.7 cu ft common chamber ported box INSIDE my trunk for my two 15's, firing into the cabin sealed off from trunk in my 01 Impala. Never have I done either one. Pretty sure I can handle the box but one little question on sealing it off.
I spent about 4 hrs researching the placement of the box and didn't find what I wanted to know. Im going to do a one peice baffle to put between the cabin and box.
If installing my baffle about a 1 ft from cabin will I lose a good amount of bass since it's not all the way up to the seats?
I don't want to block access to my fuel pump or strut towers. Everything from the baffle forward will be sound deadened including the rear deck. Also the back of the box will be a couple inches from my trunk lid so I could use that space between the cabin and box for my amp.
Box measurements are W: 38 H: 17 D: 28, as far as tuning I'd like to be around 30-35 hz. Never built a box with aero ports but from what I've read and the width of the box I can get away with two 6" ports in between the subs one at top and one at bottom. Haven't quite figured out length of ports yet.
Thanks for any help and advice in advance.
Old 02-08-2014, 08:15 PM
vince79vette's Avatar
0/11 sssss2011
So what's ur question. Is it how u should seal off the box from the rest of the trunk
Old 02-08-2014, 08:23 PM
0/11 sssssss22
I've read enough to see how it's done but out of all the builds and discussions I've looked at every box is pushed all the way up to the cabin. Will it hurt to have it recessed in the trunk a foot, as long as it's 100% sealed off from baffle back?
Old 02-08-2014, 08:39 PM
0/11 sssss2011
U can do panels to make it like a tunnel that is removable
Old 02-08-2014, 08:41 PM
0/11 sssss2011
Another way ppl do is foam it. U also can foam inside a bag to protect ur interior
Old 02-09-2014, 08:17 AM
0/11 sssssss22
Alright cool, I was thinking the tunnel idea I just didn't know for sure cause I don't think I've really seen it.
Old 02-09-2014, 11:21 AM
0/11 sssss2011
Ya I have seen it in a few builds where they have a slanted back seat and don't want to try and figure out angles
Old 02-09-2014, 11:22 AM
0/11 sssss2011
Then do the foam in a garbage around that and if u ever have to get in there it won't be a mess and it's easy to remove and seals pretty good too
Old 02-09-2014, 11:27 AM
0/11 sssssss22
Sweet, thanks for the info. I'll have it in the build log next week hopefully it could help others in the future with a sealed trunk or how to build a box in a trunk.
Old 02-09-2014, 12:32 PM
0/11 sssss2011
Ya man trunk builds are a pain. Glad I could help man.
Sedan, trunk sealed, 15s in back seat firing up question. Kelocyde General Car Audio Discussion & Questions 4 08-23-2012 02:49 PM
building a box inside the cabin of a trunk car. MERQUE General Car Audio Discussion & Questions 6 03-13-2012 11:05 AM
Building box in trunk: Tips Drillrig52 Enclosure Discussion & Design Construction Help 9 11-20-2011 12:22 AM
box question before i start building massivespl General Car Audio Discussion & Questions 65 10-19-2011 11:51 PM
anybody got any tips for building a box in the trunk Craig28 Enclosure Discussion & Design Construction Help 11 05-05-2011 11:27 PM
