solid baffle wall build question - Car Audio Classifieds!
Old 02-10-2014, 07:55 AM
0/11 ssssss855
Default solid baffle wall build question
so the question goes as follows do you just make the actual baffle as thick as the port needs to be ? Has anyone has any personal tips and tricks over this do*s and donts ? looking yo try something diffrent besides a flat wall ...
Old 02-10-2014, 07:56 AM
0/11 ssssss855
to**
Sent from my SPH-L710 using Tapatalk
Old 02-10-2014, 08:01 AM
vince79vette's Avatar
0/11 sssss2011
The front baffle on my 6th order is 2x3 till I get the area I need than u can screw 2x3 into the box to get the tuning u want than ether fiberglass it or 1/4in board and cover all the 2x3 and fiber glass that or caulk it.
Old 02-10-2014, 08:03 AM
0/11 sssss2011
Here is a pic before it was done but u get an idea
Old 02-10-2014, 08:17 AM
0/11 ssssss855
just poked around the interwebz and came up with lennys build and russ build
Old 02-10-2014, 08:18 AM
0/11 ssssss855
Old 02-10-2014, 10:09 AM
Infinitelybaffled's Avatar
0/11 ssssss816
Yah, Usually all of the ultra loud builds have insanely thick baffles.
Inappropriate sig image.
Old 02-10-2014, 10:53 AM
xnewbx's Avatar
0/11 ssssss985
It would make sense to make your port the same depth as your front baffle.
Old 02-10-2014, 12:06 PM
0/11 sssss2011
If u don't want to go crazy thick u can always use gas pipe as bracing
Old 02-10-2014, 12:28 PM
team dc audio
0/11 sssss1268
Thick helps to keep the speakers from unloading wierd in a flatt wall.
My Infinite Baffle wall experiment stylez12321 General Car Audio Discussion & Questions 15 08-29-2013 07:48 PM
Baffle question KTMrida4life General Car Audio Discussion & Questions 2 12-27-2012 03:12 AM
Baffle question. And construction help regizzle Enclosure Discussion & Design Construction Help 7 01-13-2012 08:01 PM
Double Baffle Question?? tntahoe General Car Audio Discussion & Questions 2 05-02-2011 01:29 PM
slanted baffle question... HeadAche Enclosure Discussion & Design Construction Help 17 03-04-2010 08:54 PM
