Box For MT 12's - Car Audio Classifieds!
Old 09-30-2008, 04:27 PM
peas247's Avatar
Loyal Member
0/11 sssss1001
Default Box For MT 12's
i am just tryin to get some ideas. ill be reconing the subs in the next couple weeks. i can roughly get 6.5 to 7 cubes in my trunk before displacement. i have alway built musical boxes tuned to between 30 and 33hz. plus i have always run 15s and 18's. i am aiming this build to be musical and spl. also wantin to try areos this time. what would be a good tuning. i am thinkin around the lines of 38hz maybe? also what would be best with aeros 4 4"ers or 2 or 3 6"s. any input would be great
ca.com refs - dumple(x2), banginexplorer, r/t pimp(x2), select127, joey2714, rollerdj, lincolntc690, psychoacoustics, mk_, boltpride, SHiZNiLTi, emaxaudio, yunvme666, Coolwazabi, ssackett, JBGabriel, avs20, siddle, ddbump, mike465, andrizzle, SPY
Team Low Hurtz
Old 09-30-2008, 05:07 PM
0/11 sssss1123
Best bet is to tune high, but i wouldnt use aeroports unless its a rex
Old 09-30-2008, 05:14 PM
ssackett's Avatar
0/11 sssss3349
Feedback Score: 21 reviews
I would say tune high as well. SPL Guru if he working with limited space wouldn't using aero's be a way to go??
2011 Street A National Champion
Sundown Audio Dealer
Incriminator Audio Dealer
Old 09-30-2008, 05:18 PM
0/11 sssss1123
Not really-
he has 5+cu to work with, and if you want #'s, the boxes are smaller..
Old 09-30-2008, 05:21 PM
0/11 sssss1123
your wanting to find the res. freq of your vehicle and peak there.
So if its 44hz (resonant freq) then you will tune from 4-6hz lower.
Old 09-30-2008, 05:43 PM
peas247's Avatar
Loyal Member
0/11 sssss1001
well then i am righ ton par with the tuning around 38. box is gonna be sealed off from the trunk sub and port forward. so i should stay with a slot over aeros. only reason i wana try aeros is so i can play around with the tuning instead of tearin out and rebuildin boxes everytime.
Team Low Hurtz
Old 09-30-2008, 05:47 PM
peas247's Avatar
Loyal Member
0/11 sssss1001
but i still want it to be a musical box, not just a burp box. i would just like to burp it once and a while at a big local cruise night we have and the local shows every once in a while
Team Low Hurtz
Old 09-30-2008, 05:50 PM
MR_MT's Avatar
Active Member
0/11 ssssss741
5 cubes tuned to 37-38hz would sound great
that is if you have 2 12's.
Nothing special
Old 09-30-2008, 06:00 PM
peas247's Avatar
Loyal Member
0/11 sssss1001
yeah i do i'm in the process of gettin one more recone kit then i am gonna put m together.
Team Low Hurtz
0/11 sssss1123
well tuned to 36-38 will be musical, and also peak you close to that 44hz!
[SOLD]2 Fi bl fully loaded 12's Slam 12" Subwoofers 30 01-14-2009 08:29 PM
3 10's or 2 12's Louder?? Blackout General Car Audio Discussion & Questions 19 11-11-2008 08:50 AM
Box build for 2 RD Sonance V2 12's SPY Off Topic Chat 0 10-23-2008 05:16 PM
