enclosure help ?? - Car Audio Classifieds!
Old 02-23-2014, 09:10 PM
0/11 sssssss52
Default enclosure help ??
I've ran some #s through a box calculator and got conflicting results. So, I tried the old school way. Can someone help check my figures?
Enclosure is 48w x 20d x 28h (includes double baffle). Port is 7.5h x 18.5w x 20d.
Thanks for any help
Old 02-23-2014, 09:16 PM
mega fatty
0/11 sssss6008
im getting 11.27cf tuned to 33
minus sub displacement
07 mazdaspeed3
rd d9 @ .5ohm
Old 02-23-2014, 09:42 PM
0/11 sssssss52
The way I figured was
46.5w x 18.5d x 25.75 =(12.81cuft)
Port volume I did
8.25h x 18.5w x 20d =(1.76cuft)
12.81-1.76= 11.05 cuft
11.5 - .42(subs) - .4(bracing) = 10.23 cuft @ 34.5hz
I appreciate your help. I am trying to figure out the most accurate way of doing it. I did use a port length calculator but...
Old 02-23-2014, 09:44 PM
0/11 sssssss52
The enclosure is for 3 sundown zv3 15s on 2 crescendo 3500s strapped @ 1.3
Old 02-23-2014, 10:04 PM
0/11 ssssss226
gross volume 13.19 cubes
port volume 1.93 cubes
subs displacement say .75 cubes
port area 138.75 in2
port area per foot 13.91in2
NET volume 10 cubes @ 35.5HZ
Old 02-23-2014, 10:06 PM
0/11 ssssss226
slot port tune is say your total length of port wall is 12 inches then you have to add .5" for total tune.
so total port length is 20.5" but physically its 20 inches only from face to end of wall.
its an invinsible .5" you add.
Old 02-23-2014, 10:08 PM
0/11 sssssss52
Thanks for your help. Could you share how you came up with those #s? I am trying to see what I am doing right or wrong.
The subs face up and port is on side at bottom
Old 02-23-2014, 11:07 PM
0/11 ssssss226
12volt sub box calc
torres box calc
Can I change this 4.0 f^3 single 15" enclosure into a single 1.5-2.5 12" enclosure? graham Enclosure Discussion & Design Construction Help 7 02-18-2014 09:19 AM
Enclosure Build: 12" 'standardized' daily enclosure, Dougie style Pioneer~Saturn Build Logs 59 05-20-2013 05:32 PM
Enclosure Build: 10" IAD Reign Demo Enclosure ;) Pioneer~Saturn Build Logs 57 11-18-2012 02:58 PM
Enclosure Scapelli21 Wanting to Buy (WTB) 0 11-13-2009 02:13 PM
