Quick question about jasper jig - Car Audio Classifieds!
Old 02-26-2014, 03:29 PM
0/11 ssssss249
Default Quick question about jasper jig
So I bought the model 200 and it says its calibrated for a 1/4 inch bit but I have also read where you need to subtract the 1/4 inch from your setting on the jig?
Which is it? Thanks in advance.
Old 02-26-2014, 03:31 PM
Jeffhulbert50's Avatar
Authorized Vendor
0/11 ssss14115
calibrated for a 1/4" bit should mean using a 1/4" bit and the numbers will be correct, no +/-
snyderd758 (02-26-2014)
Old 02-26-2014, 03:53 PM
0/11 ssssss249
Got it. Thank you!
The Following User Says Thank You to snyderd758 For This Useful Post:
LyferXB9s (02-26-2014)
Old 02-26-2014, 03:57 PM
socalxj's Avatar
0/11 sssss2371
For ID circle cuts measure from outside edge of bit to center of pin. For OD circle cuts measure from the inside edge of bit to center of pin. 1/4" double fluted upspiral bits work best, they cut faster and make less dust.
Shop Bosch 1/4-in Double Flute Upspiral Router Bit at Lowes.com
Old 02-26-2014, 04:05 PM
0/11 ssssss249
Yeah that is what I have. The jig has the cut measurements on it I just wanted to make sure it would've accurate and I didn't have to take into account the diameter of the bit.
Jasper jig template kurupt305 Wanting to Buy (WTB) 4 10-18-2012 01:02 PM
Jasper jig 97T5WAGON General Car Audio Discussion & Questions 4 11-04-2011 02:29 PM
Jasper Circle Jig teamsolo General Car Audio Discussion & Questions 31 03-05-2010 10:27 PM
bnib Jasper Jig tehbert0 Miscellaneous Stuff For Sale 1 01-22-2010 07:09 PM
