Hows this box for 2 Z v3 18s - Car Audio Classifieds!
Old 02-26-2014, 07:43 PM
0/11 sssss1090
Default Hows this box for 2 Z v3 18s
Hows this for a box with 2 18s?
Was thinking about running a rod right thru the middle of the box and use nuts and washers to stablize the port walls?
Also going to be inverting the subs
thoughts?
pics small but...
Gross volume 13.62ft2
Physical port length 14.25 in
Port Volume 1.48ft2
Port Area 135.0 in2
Port Ratio 1:3.75
Net Volume 11.39 ft2
Tunning Freq 36hz
Old 02-26-2014, 07:57 PM
jigsizzle's Avatar
Jet Life
0/11 sssss2274
Depends on the 18's chief...
11 net?, way too small for most 18s I believe..
Sent From Oklahoma
Old 02-26-2014, 08:01 PM
tony30cl's Avatar
WE DEM BOYZ
0/11 sssss7527
Feedback Score: 22 reviews
Sent From Oklahoma
no...not really.
it depends on what you want. typicly smaller enclosures are less efficient and more peaky. however this can work in your favoe
Old 02-26-2014, 08:08 PM
0/11 sssss1090
Sent From Oklahoma
Its for 2 Sundown Zv3 18s, I herd they like smaller box's? That 6cubes is too much airspace in many applications
And goal is just to sound good but get down. Its going into an expedition, am hopping to still be a daily ground pounder
Old 02-26-2014, 08:13 PM
djscrubb's Avatar
Captain $hit disturber
0/11 sssss2332
i have a pair of zv3 18s in 12.5 cubes net tuned to 31 with 16 inches per foot for port area. im clamping 4k to the pair and play down to 20hz. however its scary knowing that im 2 cubes larger then recommened and i have bottomed out the sub once. im pretty sure im right at the limit. honestly i would do 10 cubes max for the pair
Old 02-26-2014, 08:30 PM
0/11 sssss1090
Interesting. So they do like smaller box's then normal 18s. How do they take the 4k power? Im thinkin about pushing the same eventually. You think the 16 inches per sq ft of port area is justice for the subs? My design is putting me at 12.
If i made the port 7inchs wide that puts me at 10.5 cubes at 37hz and would be 14.6 in per foot for port
Im not really a big fan of 20hz, i like killing it at 35-45hz area would this be tunned too high?
Old 02-26-2014, 10:10 PM
djscrubb's Avatar
0/11 sssss2332
they take huge box with 4k surprisingly well. got stinky once though but was clipping. as for port area no idea what less would do.
"If i made the port 7inchs wide that puts me at 10.5 cubes at 37hz and would be 14.6 in per foot for port"
sounds pretty good. no expert though
Old 02-26-2014, 10:34 PM
jigsizzle's Avatar
Jet Life
0/11 sssss2274
Listen to them, they know more than me... Lol..
Sent From Oklahoma
Old 02-26-2014, 11:38 PM
18psi's Avatar
0/11 ssssss500
I had 2 in 9.5 cubes tuned at 34 on a saz4500 non wall, did low 50's on music . One of my more efficient builds lol
Sent from my SPH-L710 using Tapatalk
Old 02-27-2014, 12:08 AM
0/11 sssss1090
if you dont mind me asking what was your port per sq foot?
Ive got 2 port designs right now cant figure out which on i like...
7.5 Width by 18 long making it
port area per foot: 14.93
Net box volume: 11.30
Tuning 35.20 hz
OR
6.5 Width by 18 long
port area per foot: 13.12
net bot volume: 11.15
tunning 33.64 hz
I keep going back and forth.....
box for two 18s box by ben ben ahn Miscellaneous Stuff For Sale 0 08-29-2013 10:08 AM
Need you guys help with box four sundown zv3 18s ported box 12k rms. Mnorwood01 (Sundown Audio) 56 04-08-2013 05:38 PM
Hows my box look? KTMrida4life General Car Audio Discussion & Questions 27 08-07-2012 08:11 PM
4th order for OA 18s..Hows this sound? SPLEclipse General Car Audio Discussion & Questions 16 07-04-2012 11:33 AM
Hows this box sound review it plz on1wheel01 Enclosure Discussion & Design Construction Help 5 03-11-2011 10:03 PM
