Sealed side for 2 15'' ZV4s. Help please - Car Audio Classifieds!
Old 03-02-2014, 10:10 PM
0/11 sssss1417
Default Sealed side for 2 15'' ZV4s. Help please (vid of hair trick)
can i have some opinions on what is the smallest i could go on the sealed side for 2 zv4 15s? 4th order.
if you have built for this sub, i would like input. thanks.
Old 03-02-2014, 10:31 PM
0/11 sssss1785
1.75 -2 per driver
Old 03-02-2014, 10:50 PM
0/11 sssss1417
did anyone ever try 1.5? i think i might be able to get 1.75 after displacements, but thats cutting it real close.
Old 03-02-2014, 10:53 PM
e46inperrycounty's Avatar
SPL Farms
0/11 sssss5706
Use poly fill and invert them. Should help out a good bit with sealed side
2 Ampere 3.0v2 18's
BC5500 at half ohm
Mark Antony gs380.4
Anarchy 6.5s
AB sq6b's
Team SPL Farms
Old 07-13-2014, 02:55 AM
0/11 sssss1417
Can Anyone with experience with these in a band pass chime in? 1.75 net per too small?
Old 07-13-2014, 04:33 AM
0/11 sssss4519
1.75 Is perfect. We just shrank the sealed to 1.5 each on a buddies NSv2 setup. Still plays down to 12hz with authority.
To find sealed resonance
resolve Vas/28.32 =
result of that +1
square root that result
Old 07-13-2014, 09:07 AM
BigBen's Avatar
0/11 sssss3006
Feedback Score: 24 reviews
1.5-1.75 at most with the amount of motor force. Start at 1.5 then add filler if the sealed resonance isn't low enough for your tastes
Old 07-14-2014, 02:46 AM
0/11 sssss1417
If I could do 1.5 then that would be better. Lol thanks for your input. About to build my box, just debating whether to do a large ported or 4th
Old 07-14-2014, 11:36 AM
BigBen's Avatar
0/11 sssss3006
You could either do 1.75 then add wood blocks in it to shrink it later, or do 1.5 and add poly till it sounds right.
Old 07-14-2014, 09:36 PM
0/11 sssss1417
I think I can squeeze 1.75 each. Anyone with experience with these think I should start with half cone area for these. I heard they like a lot of port.
How crucial are inside wall angles on the sealed side? Robertvon Enclosure Discussion & Design Construction Help 4 11-12-2013 06:31 AM
1/0 side by side terminals w/extenders bigboygmc Car Audio Trader (WTT) 2 08-25-2013 02:08 PM
Side by side b2 xc and ssa zcon liljestrand General Car Audio Discussion & Questions 371 11-16-2012 06:50 AM
The LOUDEST side by side on EARTH!!! twistedchild420 Member Rides & System Pictures 19 07-16-2011 03:00 PM
four sealed 15'' hcca's in a bmw? justin smith Car Audio Videos 26 08-17-2010 06:30 PM
