help with port tuning - Car Audio Classifieds!
Old 03-08-2014, 04:59 AM
0/11 sssssss11
Default help with port tuning
My box is around 10.4 cubes for two Zv4 15. Power is a saz 5000D. I am going to be using a 12" round port. How long would it need to be to get the tuning in the low 30's? I forgot to say the subs are inverted so very little displacement if any.
Thanks for any help
Daniel
Old 03-08-2014, 06:08 AM
0/11 sssss2649
A 26" long port has about 1.7 cu of displacement (non flared). If you throw it in a 10.4 cu box, you'd be left with about 8.7 cu tuned at 32 hz. Anything between 22-26" long port would work well.
Old 03-08-2014, 07:47 AM
Haelmuscle's Avatar
0/11 sssss1819
As far as I know if the port is longer than 20" or shorter than 10" there is problem with your port area!!!
Best Regards.
The Following User Says Thank You to Haelmuscle For This Useful Post:
e46inperrycounty (03-08-2014)
Old 03-08-2014, 07:57 AM
e46inperrycounty's Avatar
SPL Farms
0/11 sssss5706
The port area is too great and the port will unload and subs will bottom out. Run a single 10" instead and you will be golden
2 Ampere 3.0v2 18's
BC5500 at half ohm
Mark Antony gs380.4
Anarchy 6.5s
AB sq6b's
Team SPL Farms
Old 03-08-2014, 08:02 AM
SPL Farms
0/11 sssss5706
A 10" aero at 20" long will get you down to 28hz or so and at 10" long you'll be sitting around 35hz.
2 Ampere 3.0v2 18's
BC5500 at half ohm
Mark Antony gs380.4
Anarchy 6.5s
AB sq6b's
Team SPL Farms
Old 03-08-2014, 08:06 AM
SPL Farms
0/11 sssss5706
Best Regards.
Extreme tunings will break this guideline but it will generally be the place to start and see what is in a decent efficiency range. Super short ports for high tunings for pure SPL do well and my 35" cannon isn't bad for the 23hz tune I getting out of it....lol
2 Ampere 3.0v2 18's
BC5500 at half ohm
Mark Antony gs380.4
Anarchy 6.5s
AB sq6b's
Team SPL Farms
How much Port for tuning of 35 hz? AFlem Enclosure Discussion & Design Construction Help 6 02-20-2012 10:08 PM
need help tuning pvc port jackdaniels General Car Audio Discussion & Questions 4 10-26-2011 02:14 PM
port tuning JAYARE2007MAG General Car Audio Discussion & Questions 4 11-04-2010 02:23 PM
port tuning help audiobahnfan Enclosure Discussion & Design Construction Help 8 06-17-2010 07:20 PM
port tuning? 98AckCL23 Enclosure Discussion & Design Construction Help 5 01-13-2009 02:00 AM
