help fitting subs on baffle? - Car Audio Classifieds!
Old 03-13-2014, 06:32 PM
mega fatty
0/11 sssss6008
Default help fitting subs on baffle?
This is the enclosure im doing in my blazer
i have right about 26cf before port and subs
all walls will be 1.5" minus front and rear baffle which i will probably do 3" maybe more.
subs are 4 sundown x 18's
trying to get them all on flat wall before i go making a vertical clam style.
just need some help fitting port and such.
idk how close i can put them to each other or the walls.
any help would be helpful
07 mazdaspeed3
rd d9 @ .5ohm
Old 03-13-2014, 07:10 PM
mega fatty
0/11 sssss6008
this is kinda what i was thinking, could 1" of baffle be enough around each sub?
i was kinda thinking maybe brace the front wall with 1/4" steel
07 mazdaspeed3
rd d9 @ .5ohm
Old 03-13-2014, 07:45 PM
e46inperrycounty's Avatar
SPL Farms
0/11 sssss5706
If you get them as close to the outside edges as possible you might be able to get a 16" aero in there...
2 Ampere 3.0v2 18's
BC5500 at half ohm
Mark Antony gs380.4
Anarchy 6.5s
AB sq6b's
Team SPL Farms
Old 03-13-2014, 07:47 PM
SPL Farms
0/11 sssss5706
After displacements you will be around 8 inches of aero per cube. Should do the trick
2 Ampere 3.0v2 18's
BC5500 at half ohm
Mark Antony gs380.4
Anarchy 6.5s
AB sq6b's
Team SPL Farms
Old 03-14-2014, 06:28 AM
mega fatty
0/11 sssss6008
I will see what I can fit tonight
By chance do you know the flair diameter?
And how close can I put the subs together or how close to the port before the baffle gets weak?
07 mazdaspeed3
rd d9 @ .5ohm
Old 03-14-2014, 07:33 AM
666WMD's Avatar
No idea what I'm doing
0/11 sssss1307
If you make the front baffle to the extent of the box (48x48), you can push the sub cut outs right to the edges of the internal dimensions, because only the basket needs to fit in and it tapers down to the motor. The OD of the subs still won't exceed the limits of the enclosure and you end up with 668sqin of possible port area.
Old 03-14-2014, 01:28 PM
mega fatty
0/11 sssss6008
Sorry I should have specified
Those 45's in the upper corner are the box
I just didn't cut the rest of it out but the box stops at those 45's
07 mazdaspeed3
rd d9 @ .5ohm
Old 03-14-2014, 01:30 PM
mega fatty
0/11 sssss6008
But do you think it's fine to push the subs all the way to the egg and only leave 1" between the basket and the port?
07 mazdaspeed3
rd d9 @ .5ohm
Old 03-14-2014, 10:20 PM
666WMD's Avatar
0/11 sssss1307
I was bored -
I don't see any issue with putting the subs close to a port. Any weakening of the baffle will be negated by the port bracing it. Just use the same thickness for the port as you do the walls.
Old 03-14-2014, 10:39 PM
mega fatty
0/11 sssss6008
Ok
I think I will just go with my odd shaped port and make the front baffle 6"
07 mazdaspeed3
rd d9 @ .5ohm
JL IB4-10 Infinite Baffle Subs (three) jimbno1 10" Subwoofers 1 12-24-2012 05:00 PM
4.27 cube box for sale for 2 12 inch subs 67.5 sqin of port double baffle never used Jason19 Miscellaneous Stuff For Sale 1 06-16-2011 06:13 AM
fitting a d3100 aviator08 General Car Audio Discussion & Questions 2 06-25-2010 06:34 PM
Battery fitting aviator08 General Car Audio Discussion & Questions 0 12-18-2009 02:02 PM
