2)18 fi Q in geo metro - Car Audio Classifieds!
Old 04-12-2014, 03:35 AM
0/11 sssssss22
Default 2)18 fi Q in geo metro
I have a 93 geo hatch I gutted and wanna drop in 2 18" fi q ..I have room for a 12 cbft box and I wanna run aero ports ..I have no idea what to do I'm getting different sizes from different calculators ...I wanna tune the box to 32 maybe lower ..I just need to know what size and how many aero ports to order...I have 2 4"x12 aero ports laying around could I use those? ...any help
Old 04-19-2014, 06:55 PM
0/11 sssss1411
if you wana do a box or a wall ? you could gain more cubic ft for a wall id imagine - but youd have to build inside the car - and it would probably sound weird sealed up - but with the windows down or a door open man it would jam.
is it for daily bumping ? the q is a great daily sub on music
Old 04-19-2014, 07:00 PM
0/11 sssss1411
edit double posting
Old 04-19-2014, 07:09 PM
666WMD's Avatar
No idea what I'm doing
0/11 sssss1307
You'd want at least 3 4" ports per 18, 2 6" each would be better. 12cuft net would just be enough for the 2, but material and port/sub displacement will bring your gross cuft up closer to 14.
Maybe post up dimensions you have to work with and someone will be able to help you.
Old 04-20-2014, 03:32 AM
0/11 sssssss22
It's either the 2 18" or a rockford 12t2 I kinda wanna keep my gas mileage ...I have 40L 35w 18h I had a 18 Q in my fusion 3.5cbft tuned to 30 and it was nasty ..I'm just confused should I do 1 12" t2 or the 2 18" q
Old 04-20-2014, 09:49 AM
0/11 sssss1411
if you can stack in enough electrical to handle or barely almost handle the pair of 18s then do them. that much cone in such a small airspace will slam - it could be a realley fun demo viechle
but if its your only viechle - daily driving to work and back grocery getter bla bla
then its not smart to turn it in to a all out ground pounder. you might end up needing better suspension for the weight - a small bank of batterys and a high out put alternator as well as sound deadning the car and a front stage that can keep up with the subs = dumping tons of $$ in to a car that you may or may not LOVE.
i dont recomend people to build cars that they dont LOVE... no sence in droping that cash on less than ideal for what you can work with ya kno ?
Old 04-20-2014, 11:35 AM
0/11 ssssss543
Why 2 18's or 1 12? Why not just 1 18?
Geo metro build help S.O.B General Car Audio Discussion & Questions 2 09-26-2013 11:21 PM
Geo metro build ..need help S.O.B Enclosure Discussion & Design Construction Help 7 07-11-2013 01:41 AM
1996 Geo Metro :) PlugItIn Miscellaneous Stuff For Sale 2 01-04-2010 09:27 PM
My 91 Geo metro with a Fi Q 12" EricM9104 Build Logs 19 10-14-2009 03:46 AM
