thoughts on 2 18s in a 4th no wall - Car Audio Classifieds!
Old 04-16-2014, 05:00 PM
Biggy's Avatar
Loyal Member
0/11 sssss2240
Default thoughts on 2 18s in a 4th no wall
Hey,
im planning my next Setup, i got 2 Sundown Nightshade V1 18s with PSI Recones, will be run of off 2 SAZ3000
car is a 92 VW Passat Wagon, daily groundpounder
I got about 19-20cubes to play with.
Space depends on if i want the Port to the back or to the top.
Plan was 3cf sealed and 7.5-8cf ported per sub. 250squareinches of Port @47hz
what are your thoughts on this?
If you hear any Clipping, it may be your Ears or the Coils hitting the End Stop
Sundown Audio Germany
Hey, what can I say? I love me some poonanner. Even if I have to hit them with a door and handcuff to the chair.
Thoughts on this wall design??? need help nate56 Enclosure Discussion & Design Construction Help 0 03-26-2014 03:15 PM
4th order wall or flat wall Dirtbikerrob Enclosure Discussion & Design Construction Help 9 03-05-2013 09:25 PM
Silverado Rebuild, 2 xsv2 18s 4th order wall Re_Silverado Build Logs 143 02-18-2013 01:31 AM
4 OA 18s. Wall or 4th? btsteinb Enclosure Discussion & Design Construction Help 36 08-21-2012 02:35 PM
ported wall or 4th order wall jmkanek Enclosure Discussion & Design Construction Help 12 05-12-2012 08:37 PM
