Four Sundown X12s 6.6cubes @32Hz - Car Audio Classifieds!
Old 04-18-2014, 05:34 PM
So Low's Avatar
0/11 sssss1258
Default Four Sundown X12s 6.6cubes @32Hz
This is for BigWill1971 per request
Same image as above but with cutouts visible
Two sheets thick all the way around, except port walls. 3/8" roundover on port walls inside and out, and around the top/sides of the box and outer baffle.
The woofer placement is tight, I know the numbers come out weird but Im sure you can get them close.
Happy building
Old 04-18-2014, 06:45 PM
0/11 ssssss139
Thanks bro, looks awesome.
Old 04-18-2014, 07:11 PM
So Low's Avatar
0/11 sssss1258
Missed one picture sorry! Hole cutouts measured to the center. As long as you clear the side walls you will be okay but I had the program put them in the ideal location. I'm sure you can get the measurements pretty close.
2 bnib sundown x12s d2 wally79 Car Audio Trader (WTT) 15 04-26-2014 08:55 PM
(2) Sundown D4 X12s NEW Black Toyoda 12" Subwoofers 5 02-19-2014 10:27 PM
2 bnib sundown x12s d2 wally79 12" Subwoofers 19 02-07-2014 09:32 PM
Team Sundown 8 SA 12s + 2 saz4500= [email protected] Soundblazin (Sundown Audio) 15 02-10-2012 01:57 PM
[SOLD LOCAL]7.6Cubes @ 34Hz RidnClean Wiring, Electrical & Other Installation Equipment 23 07-21-2009 02:55 PM
