I need port help! - Car Audio Classifieds!
Old 04-19-2014, 05:57 PM
RollerDJ's Avatar
Plays With Fire
0/11 ssss10067
Default I need port help!
I need to do 3, 3" ports that will be 22" long. Bad thing is so far that I've seen aero port only is sold in 12 and 6 inch lengths, and they are not the same standard sizes as PVC pipe. What are my best options? I also need a 90deg bend in them to.
Proud Member of CAAA!
Old 04-19-2014, 06:14 PM
RollerDJ's Avatar
Plays With Fire
0/11 ssss10067
I also found this option...
https://www.youtube.com/watch?v=fzdnlBkG2mI
Is that as easy at it looks?
Old 04-19-2014, 06:22 PM
tony30cl's Avatar
WE DEM BOYZ
0/11 sssss7526
Feedback Score: 22 reviews
just use pvc and couplers then flare it
Old 04-19-2014, 06:27 PM
here
Old 04-19-2014, 06:38 PM
RollerDJ's Avatar
Plays With Fire
0/11 ssss10067
I forgot dayton sells stuff for ports... but crap, 207 dollars for port parts. I think I might play around with a heat gun and see what I can come up with!
Old 04-19-2014, 06:42 PM
RollerDJ's Avatar
Plays With Fire
0/11 ssss10067
There will be a total of 6 3" ports. 3 per enclosure with a single SI 15" HT subwoofer.
Old 04-19-2014, 07:31 PM
666WMD's Avatar
No idea what I'm doing
0/11 sssss1307
Are you trying to jam them in a small space around the sub? 2 4" ports would only be 3sqin more port area.
Old 04-19-2014, 09:37 PM
RollerDJ's Avatar
Plays With Fire
0/11 ssss10067
It's 4.8 ft^3 tuned to 22hz. While 2 4's are not to far out of the question, it does mean a little longer for 4" ports to do 24hz. I could go up to 2 4's tuned to 26hz I can get away with using a full length aero port.
Old 04-19-2014, 09:44 PM
0/11 ssss31257
just go with a 2.5"x9" slot 21 1/2" long
Box designs for $35.
My 'business' name is BBS (it means Built By Sonic)
I'm in Waterloo Iowa.
I do box designs for $35 paid before hand.
Most designs are done within 2 days.
V this picture is a link... click it V
Old 04-19-2014, 09:46 PM
RollerDJ's Avatar
Plays With Fire
0/11 ssss10067
Originally Posted by iamsonic View Post
just go with a 2.5"x9" slot 22" long
Box is already cut up and ready for assembly once I get the port stuff down. My goal is to look something like this, but with a nice dark stained veneer.
http://www.svsound.com/subwoofers/ported-box/PB13-Ultra
Cartunz 3X show 6-24-2012 $500 for loudest non Port or Super Port score bdufner Competition Corner 2 06-16-2012 07:29 AM
