port area - Car Audio Classifieds!
Old 04-24-2014, 06:22 PM
0/11 ssssss822
Default port area
Hello im trying to learn how to design boxes but im stuck with the port area. I know the general rule of 9-12 inches for aeros and 12-16 for slots. So my question is when do u use the low side or higher side of port area?
01 tahoe 80prs
275 & 350 singer alt
2 black cherries
levi iii
2 12's dds tridents
4 cf 8's & vifas xt25's
Old 04-25-2014, 08:05 AM
0/11 sssssss12
Someone can chime in if I'm wrong, but I've always used the smaller area if I'm going for more of an sq build
Sent from my Galaxy S4 via Tapatalk
Old 04-25-2014, 08:52 AM
0/11 ssssss522
Port area depends on several factors. Mainly subs specs and tuning goal.
Old 04-25-2014, 09:00 AM
e46inperrycounty's Avatar
SPL Farms
0/11 sssss5706
If you are going for a lower tuning it will be easier to achieve it with the lower end of the port area ratio. For and SPL build you want to get as much port area as possible while still having good compression. The other thing port area effects is port velocity. Less area = more velocity and a better chance of port noise so you have to be careful
2 Ampere 3.0v2 18's
BC5500 at half ohm
Mark Antony gs380.4
Anarchy 6.5s
AB sq6b's
Team SPL Farms
The Following User Says Thank You to e46inperrycounty For This Useful Post:
SCS_Audio (04-25-2014)
Old 04-25-2014, 09:08 AM
0/11 sssss2011
Feedback Score: 61 reviews
there is so much more to port area than going with a general rule. that's a lot for aero ports. I personally use 4-9 sq in for aeros, 6-10 sq in for round, 12-16 sq in for slotted or rectangular. i use BBP6 so that there is no question when I start building. I've had many installers that I work with try to tell me "you're wrong" when I tell them what I'm building for a specific enclosure but once they see how it plots on a graph compared to what they think they know. when it comes to port area and you are wanting to go "small" you'll most likely encounter port noise. I always stay between 20-30 m/s for pv which the rule of thumb usually keeps pv in the safe realm of 15-25 m/s. when building port enclosures I personally believe it's all about getting the velocity right. if I plot an enclosure and the velocity is less than 20 m/s, I keep making adjustments till I get over the 20 m/s mark. when i first started off I thought I knew what I was doing but I look back and see there was little to no velocity. those boxes sounded good but now I'm more about the velocity. now all my boxes now sound awesome and move air like fans w/o noise.
Old 04-25-2014, 09:14 AM
SPL Farms
0/11 sssss5706
I think with my 38hz SPL port in my port velocity is 130fps... I don't care how that port sounds, the daily port sounds great...lol
2 Ampere 3.0v2 18's
BC5500 at half ohm
Mark Antony gs380.4
Anarchy 6.5s
AB sq6b's
Team SPL Farms
Old 04-25-2014, 09:40 AM
Todd Dupler's Avatar
Team SPL Farms
0/11 sssss5000
Hairtricks at 40 rule
01 Volkswagen Golf 2 door
Kenwood ddx470
Old 04-25-2014, 10:07 AM
0/11 ssssss822
Thumbs up
there is so much more to port area than going with a general rule. that's a lot for aero ports. I personally use 4-9 sq in for aeros, 6-10 sq in for round, 12-16 sq in for slotted or rectangular. i use BBP6 so that there is no question when I start building. I've had many installers that I work with try to tell me "you're wrong" when I tell them what I'm building for a specific enclosure but once they see how it plots on a graph compared to what they think they know. when it comes to port area and you are wanting to go "small" you'll most likely encounter port noise. I always stay between 20-30 m/s for pv which the rule of thumb usually keeps pv in the safe realm of 15-25 m/s.[/COLOR] when building port enclosures I personally believe it's all about getting the velocity right. if I plot an enclosure and the velocity is less than 20 m/s, I keep making adjustments till I get over the 20 m/s mark. when i first started off I thought I knew what I was doing but I look back and see there was little to no velocity. those boxes sounded good but now I'm more about the velocity. now all my boxes now sound awesome and move air like fans w/o noise.
Very good info but you lose me with the"m/s"
01 tahoe 80prs
2 black cherries
levi iii
2 12's dds tridents
The Following User Says Thank You to alacran For This Useful Post:
massivespl (04-25-2014)
Old 04-25-2014, 10:35 AM
SPL Farms
0/11 sssss5706
Meters per second = m/s. It is the speed that the air is moving in and out of your port. Too much speed and you get port noise, too little speed and you lose compression inside the enclosure.
2 Ampere 3.0v2 18's
BC5500 at half ohm
Mark Antony gs380.4
Anarchy 6.5s
AB sq6b's
Team SPL Farms
Old 04-25-2014, 11:35 AM
HACKMUNCH's Avatar
0/11 sssss3892
Boundary layer and turbulence is your enemy but port compression is your friend.
Sent from my HTC6435LVW using Tapatalk
TEAM TSA 2013
FACTORY BACKED
XS POWER - 4XSPOWER.COM
PSI - PSICARAUDIO.COM
help with port box a per and port area per ft lilsoccersully Enclosure Discussion & Design Construction Help 0 05-02-2012 09:04 PM
Port area vs. Port length TaylorFade General Car Audio Discussion & Questions 3 10-20-2011 09:52 PM
port area for 1 sa 12?? thekernal123 (Sundown Audio) 7 05-25-2011 09:14 PM
help me with port area jwesenick79 Enclosure Discussion & Design Construction Help 5 01-08-2010 12:22 PM
