4th order sealed resonance, no wt3 - Car Audio Classifieds!
Old 04-24-2014, 11:19 PM
0/11 sssssss31
Default 4th order sealed resonance, no wt3
First, I've read the 4th order thread...more than once, lol.
Second, Parts Express isn't selling the dats right now, for who knows how long.
Third, the "woofer tester" is about half the money of a imsg. If I was going to get the wt, I might as well get the imsg but I don't want to spend that much right now.
So my questions are, how do I know what to tune my ported chamber to? 8 sa-12's, 1 cuft sealed each, 3 cuft ported. Is the sealed side resonant frequency different in my vehicle compared to a different vehicle with the same encloser?
Old 04-24-2014, 11:26 PM
mega fatty
0/11 sssss6008
The sealed side will be the same in any vehicle
You could just wing it with a temp loading wall tuned to like 45hz
Just saying 8 cf for 8 12's seems a bit on the small side but I'm not too sure with the sa's
07 mazdaspeed3
rd d9 @ .5ohm
e46inperrycounty's Avatar
SPL Farms
0/11 sssss5706
Sealed resonance won't be affected by your vehicle. It is more about the woofers and volume of sealed enclosure. There is a formula that you can use to find sealed resonance without using software to do it for you but you will need the tsp's from the woofers you are using and the net volume of the enclosure.
2 Ampere 3.0v2 18's
BC5500 at half ohm
Mark Antony gs380.4
Anarchy 6.5s
AB sq6b's
Team SPL Farms
Old 04-24-2014, 11:31 PM
SPL Farms
0/11 sssss5706
I think the formula is.... Fc=Fs×√(Vas/VB)+1
2 Ampere 3.0v2 18's
BC5500 at half ohm
Mark Antony gs380.4
Anarchy 6.5s
AB sq6b's
Team SPL Farms
Old 04-24-2014, 11:35 PM
0/11 sssssss31
Ok, thank you! I think it's around 46-47hz in 1 cuft. Does that sound about right?
*looking up t/s now*
Old 04-24-2014, 11:37 PM
SPL Farms
0/11 sssss5706
Sounds close iirc... If you tune to 46 it should theoretically play down to the 20's before it really rolls off hard with the 3:1 ratio you have going.
2 Ampere 3.0v2 18's
BC5500 at half ohm
Mark Antony gs380.4
Anarchy 6.5s
AB sq6b's
Team SPL Farms
Old 04-24-2014, 11:42 PM
0/11 sssssss31
Thanks again! Thats what I was shooting for, but didn't know how to "check" now.
Old 04-24-2014, 11:43 PM
SPL Farms
0/11 sssss5706
Correction... @ 1ft³ you will have a sealed resonance of about 44.57hz I believe with the sa 12's. Tune loading wall to about 44 and give it a touch more port to make up the .57hz
2 Ampere 3.0v2 18's
BC5500 at half ohm
Mark Antony gs380.4
Anarchy 6.5s
AB sq6b's
Team SPL Farms
Old 04-24-2014, 11:51 PM
0/11 sssssss31
Old 04-24-2014, 11:54 PM
SPL Farms
0/11 sssss5706
I failed to mention that vas is in ft³ in that equation so you have to divide any vas shown as liters by 28.32
2 Ampere 3.0v2 18's
BC5500 at half ohm
Mark Antony gs380.4
Anarchy 6.5s
AB sq6b's
Team SPL Farms
sealed resonance frequency yotabass1 General Car Audio Discussion & Questions 0 01-17-2014 10:21 AM
how to find sealed air resonance with out software in a 4th AClassSounds General Car Audio Discussion & Questions 21 06-02-2013 09:51 PM
4th order, 6th, Ported sealed??? theking Enclosure Discussion & Design Construction Help 43 06-20-2012 04:58 PM
4th order motor in ported or sealed? drsnazzy General Car Audio Discussion & Questions 8 05-29-2012 03:33 PM
Polyfill sealed chamber 4th order? LyferXB9s Enclosure Discussion & Design Construction Help 5 04-23-2011 10:11 AM
