Sealed enclosure help, single 8" SD-2 8 - Car Audio Classifieds!
Old 04-30-2014, 11:07 PM
0/11 sssssss29
Default Sealed enclosure help, single 8" SD-2 8
I just got a Sundown Audio SD-2 8" today and I want to build the box this weekend. I am going with a sealed enclosure. Specs say for sealed the airspace is .25ft^3. My question: is that the minimum space needed or the optimal space for this sub? If it's the minimal, will bigger = better? If so, how much more space should I consider. The sub will be getting about 625w RMS and will be in a Subaru Crosstrek (hatchback). Even though I want to know if bigger is better...I'm trying to stay with a smaller box to maintain space, but if something bigger than .25ft^3 is better but not huge, I'll certainly do what needs to be done to maximize SQ.
Also, will box shape matter? Wedge vs. rectangle vs. cube?
Sorry about the questions...still new to all this.
Old 05-11-2014, 03:36 PM
0/11 ssssss103
that will be a small box even if you doubled the size. Bigger lowers Fs but at a certain point in a sealed box there will be too much air to dampen it so i wouldn't go with more than x2.5 the rec box spec.
Anybody use a Z.3 15" in a sealed enclosure? edouble101 (Sundown Audio) 18 08-27-2012 07:24 PM
sealed enclosure help lone racer Enclosure Discussion & Design Construction Help 6 10-26-2011 05:30 PM
Sealed Enclosure for (2) 10's $10 ThumpinTitan Wiring, Electrical & Other Installation Equipment 2 12-05-2010 12:31 PM
JL 13w7 Sealed Enclosure pastro100 Speaker Accessories & Parts 1 11-25-2010 01:56 PM
