Sub orientation in 4th order wall - Car Audio Classifieds!
Old 05-01-2014, 05:10 PM
0/11 ssssss697
Default Sub orientation in 4th order wall
Really thinking about doing a 4th order wall. I have my battery's and amps directly behind the front seats and don't want to have to move them. The port would be along the top, external port over the batteries. Would I be best off having sealed section on bottom of box so subs are firing down?
Rough picture of how box will be shaped.
2001 Tahoe
2 24" tantric SHD
2 American Bass 1100.1
Old 05-01-2014, 05:12 PM
0/11 ssssss697
Subs firing down. Good thing I'm such an awesome artist haha
2001 Tahoe
2 24" tantric SHD
Old 05-01-2014, 06:21 PM
mega fatty
0/11 sssss6008
you want to be careful building it this way as they can load funky and cause one or more to unload.
i dont have experience but i was going to do this exact thing with 12 12's and was cautioned.
although i have seen 2 15's like that and they played fine
07 mazdaspeed3
rd d9 @ .5ohm
The Following User Says Thank You to tymoto21 For This Useful Post:
Jager (05-02-2014)
Old 05-01-2014, 06:23 PM
tony30cl's Avatar
WE DEM BOYZ
1/11 sssss7526
Feedback Score: 22 reviews
its better if its on the back wall and facing towards the port. just the way we do it down here
The Following User Says Thank You to tony30cl For This Useful Post:
Jager (05-02-2014)
Old 05-01-2014, 07:41 PM
e46inperrycounty's Avatar
SPL Farms
0/11 sssss5706
This 2
2 Ampere 3.0v2 18's
BC5500 at half ohm
Mark Antony gs380.4
Anarchy 6.5s
AB sq6b's
Team SPL Farms
Old 05-01-2014, 09:28 PM
0/11 ssssssss9
Like your picture shows I wouldn't do it unless its just 2 of them side by side if you go 2 deep or more the ones closest to the port will tend to unload like stated above this happens because of the way the pressure in the box works the ones away from the port will he fine one's closest to the port will tend to act they are free air (ib) hope this helps you understand it
Old 05-02-2014, 01:42 AM
0/11 sssss5305
I prefer subs on one side or firing at each other.
Sub is firing UP in your pic...
4th order wall or flat wall Dirtbikerrob Enclosure Discussion & Design Construction Help 9 03-05-2013 09:25 PM
ported wall or 4th order wall jmkanek Enclosure Discussion & Design Construction Help 12 05-12-2012 08:37 PM
subwoofer orientation in a 4th order wall 18inchjeepin Enclosure Discussion & Design Construction Help 17 04-05-2012 08:29 PM
4th order wall? tommytee General Car Audio Discussion & Questions 16 01-27-2012 03:01 PM
4th order wall? Russellabt General Car Audio Discussion & Questions 0 05-21-2011 06:50 PM
