port area for aero ports? - Car Audio Classifieds!
Old 05-06-2014, 06:45 PM
LoudLancerOZ's Avatar
0/11 ssssss285
Default port area for aero ports?
I'm in the process of designing an enclosure for 2 Sundown E12's in a trunk build. It will be facing the cabin sealed off and will be my first experience with aeros. Using Torres to get my tuning at 35 (recommended for the e12's) I will need to use 2 4" aeros each 12" long. This gives me a port area of 7.20 per foot. Is this too low of port area? If so any recomendations that will work better for this application would be appreciated.
Old 05-06-2014, 06:47 PM
e46inperrycounty's Avatar
SPL Farms
0/11 sssss5706
Shoot for between 8-12" per cube with aeros to keep port velocity in check. For 35hz tuning probably be pretty efficient at tuni g with 10" per cube.
2 Ampere 3.0v2 18's
BC5500 at half ohm
Mark Antony gs380.4
Anarchy 6.5s
AB sq6b's
Team SPL Farms
Old 05-06-2014, 06:50 PM
SPL Farms
0/11 sssss5706
A single 6" @ 14" long should get your tuning to about 35 and reduce your net slightly and give better port area per cube
2 Ampere 3.0v2 18's
BC5500 at half ohm
Mark Antony gs380.4
Anarchy 6.5s
AB sq6b's
Team SPL Farms
0/11 sssss2649
Yes , 2 4's for 2 e12's in 3.5 cu would work great.
Old 05-06-2014, 06:53 PM
SPL Farms
0/11 sssss5706
Yeah its only ~3" more port area but in ~3.5 cubes it will be make a decent difference
2 Ampere 3.0v2 18's
BC5500 at half ohm
Mark Antony gs380.4
Anarchy 6.5s
AB sq6b's
Team SPL Farms
Old 05-06-2014, 06:55 PM
0/11 ssssss285
I will be making the aeros myself out of pvc. Would it be safe to add sweep elbows to make the port longer so I can use a larger diameter?
Old 05-06-2014, 06:56 PM
SPL Farms
0/11 sssss5706
Elbows really screw with flow in aeros. Just go partially external before elbows.
2 Ampere 3.0v2 18's
BC5500 at half ohm
Mark Antony gs380.4
Anarchy 6.5s
AB sq6b's
Team SPL Farms
Old 05-06-2014, 06:58 PM
BigBen's Avatar
0/11 sssss3006
Feedback Score: 24 reviews
Depends on your goals. Usable bandwidth or spl. Tuning at 35 with 7" per cube will yield a decent range, 26ish to possibly 60hz. More towards 10" per cube will be louder but won't play as wide
Old 05-06-2014, 07:03 PM
0/11 ssssss285
Originally Posted by e46inperrycounty View Post
Elbows really screw with ftransition than traditional elbows os. Just go partially external before elbows.
No room for external unfortunately. Only listen with seats down but with seats up there's only about a 1" gap between the sub's and seat. I was hoping sweep Elbows would be OK since there longer and more of a smooth transition than traditional elbows
Old 05-06-2014, 07:05 PM
0/11 ssssss285
Smile
This will be for bandwidth. After the box is done and I'm happy with the daily aspect I will build a set of ports for SPL which is why I want to go aeros
Aero ports or Bottom slot port for 2 18 box mboydrummer Enclosure Discussion & Design Construction Help 8 03-03-2014 11:42 AM
4" aero flared port kits - box ports - [email protected] Wiring, Electrical & Other Installation Equipment 7 10-20-2011 10:47 AM
how to calculate port area of an aero? fyerbyrd22 General Car Audio Discussion & Questions 25 07-10-2011 12:54 PM
less port area with aero ports? Dbmonster Enclosure Discussion & Design Construction Help 16 08-06-2010 03:21 AM
Slot ports vs aero ports? 87linkin General Car Audio Discussion & Questions 6 01-16-2010 03:09 PM
