Dual 1.3 sealed - what aero's to add/subs that will do well? - Car Audio Classifieds!
Old 05-10-2014, 02:50 PM
graham's Avatar
Tinder Douchebag
0/11 sssss7122
Default Dual 1.3 sealed - what aero's to add/subs that will do well?
I found a nice box for cheap on cl. 1.3 sealed each chamber. 1" mdf.
What aero ports will I need for 28hz tuning and what 12"s would do good with 1.3 cubes each?
Preferably dual 2 so i can wire down to .5 and give them 2k or whatever a saz1500d v1 will put out at .5
team graham
Old 05-10-2014, 03:05 PM
B-Shot's Avatar
Bass Enhanced
0/11 sssss1733
Internal ports?
Old 05-10-2014, 03:07 PM
graham's Avatar
Tinder Douchebag
0/11 sssss7122
Originally Posted by B-Shot View Post
Internal ports?
I'm not an expert on aero's - what do you mean?
team graham
Old 05-10-2014, 03:13 PM
B-Shot's Avatar
Bass Enhanced
0/11 sssss1733
Ports inside the box? If so you will lose space inside the box and need to use a smaller sub
Old 05-10-2014, 03:25 PM
graham's Avatar
Tinder Douchebag
0/11 sssss7122
How long would they be outside of the box? I've seen 8" wide aeros that were 2-3" outside of the box - would something like that be pheasable?
Would aero ports inside the box act as if they were a solid tube - taking up the entire outer diameter away from the internal space?
Perhaps converting it to a single 12" and finding a sub that would do great in about 2-ish cubes? (assuming sub displacement and aeros tale up .6 cubes?
I do have a treo ssx 12 but its 1.3 final impedence. I think i remember it needing a lot of air space but would it really get down on only 1300-1500 watts? Isnt the rule that if you give it lower power, make the box smaller? If so, doesnt that hinder the low end response drastically?
team graham
Old 05-10-2014, 03:35 PM
B-Shot's Avatar
Bass Enhanced
0/11 sssss1733
Yes ports inside the box take your air space like a solid tube, what the LxWxH of the box?
Old 05-10-2014, 03:41 PM
graham's Avatar
Tinder Douchebag
0/11 sssss7122
21x33x12 L,w,h
team graham
Old 05-10-2014, 04:22 PM
BigBen's Avatar
0/11 sssss3006
Feedback Score: 24 reviews
No way you can fit enough aero inside a 1.3 ^3ft chamber and put a 12 in it and get tuned to 28hz. I'm.guessing that a 4" aero tuned that low would be well above 20" long. Maybe 30" you're better off taking out.the divider and making it 2.6 gross for a single 12 and go from there.
Old 05-10-2014, 04:29 PM
graham's Avatar
Tinder Douchebag
0/11 sssss7122
I'm guessing that they are 2 individual boxes connected to each other...he said there is 2" in the middle.
Sounds like this would not be worth it. He only wants $30 though.
team graham
DD Subs sealed? jbattles General Car Audio Discussion & Questions 13 10-17-2012 01:03 AM
sealed subs recommendations Ringspun09 General Car Audio Discussion & Questions 6 04-28-2012 09:13 AM
Sealed 10" subs? RetroAudioInc General Car Audio Discussion & Questions 0 05-22-2010 01:24 AM
Dual 12", Sealed Enclosure Build Pioneer~Saturn Build Logs 2 03-06-2009 04:45 PM
