4th order for single nsv1 15 - Car Audio Classifieds!
Old 05-11-2014, 02:10 PM
0/11 ssssss103
Default 4th order for single nsv1 15
going to be building this box for a single nsv1 15 in the trunk. any input on this design? numbers on the left are the ported side...
Old 05-11-2014, 02:14 PM
tony30cl's Avatar
WE DEM BOYZ
0/11 sssss7526
Feedback Score: 22 reviews
whats your sealed side and what are your goals with this?
Old 05-11-2014, 03:21 PM
0/11 ssssss103
sealed is 2cuft on the nose. goal is loud daily, and i have never tried a 4th order would like to give it a shot. magnet would be in ported end.
Old 05-11-2014, 06:41 PM
tony30cl's Avatar
WE DEM BOYZ
0/11 sssss7526
i would shrink the ported to 4 cubes, if not it may be too peaky for your liking
Old 05-11-2014, 07:08 PM
SantaClawZ's Avatar
CEO, SounDrive Audio
0/11 ssssss374
What kind of Fc does 2 cubes give you? 52hz is a bit on the higher end of what I would use for daily but it should still work.
SounDrive XTerra
8 SounDrive SDA3 15s | 2 Taramps Bass 12k | 2 Taramps DSP1600 | XS D3400 | 200ah SounDrive Lithium | DC Power 320a | Mechman 170a
Old 05-11-2014, 10:31 PM
0/11 ssssss103
looks like 2 brings me to 48.xx, would it be ok to tune say 40hz on the ported side if not lower to reach down?
Old 05-12-2014, 10:59 AM
Haelmuscle's Avatar
0/11 sssss1819
The D2 NSv.1 in 2cu ft. is around 48-49 hz so adding polyfill in best situations 30% increase so .6cu ft. Increase should total 2.6cu ft. should give 46.xx hz, find your imp spike tune to it, DO NOT TUNE LOWER THAN SEALED RESONANCE because you will shred some surrounds!
Good Luck,
Kindest Regards.
Old 05-12-2014, 11:03 AM
209native's Avatar
0/11 sssss1975
Originally Posted by Haelmuscle View Post
Good Luck,
Kindest Regards.
^^^ hey hael what gives bro you cant change now
prs 80 hu
brovax cf 5.25 comps
hertz mille 6.5s
2 stinger 1700s
mechman 320
rebuilding
Old 05-12-2014, 11:21 AM
Haelmuscle's Avatar
0/11 sssss1819
Hi sir!
I'm really busy BRO, that's why I change lol,
Thank you for following me, I greatly appreciate it BRO!
Best Regards.
Old 05-12-2014, 11:30 AM
0/11 ssssss103
So do I really need to go bigger sealed for it to get low? I know bigger is lower tuning but what is too big
4th Order Single BTL N2 15 Wes669 Build Logs 18 10-10-2012 11:28 PM
single sa15 4th order tattoonick87 Enclosure Discussion & Design Construction Help 3 09-28-2012 07:44 PM
single sa15 4th order tattoonick87 Enclosure Discussion & Design Construction Help 0 09-26-2012 10:06 AM
Help on a single 10" 4th order? tandrel Enclosure Discussion & Design Construction Help 2 04-09-2012 11:44 PM
Single 15 and 4 10 4th order boxes ltr450racer690 Wiring, Electrical & Other Installation Equipment 32 04-23-2011 11:11 AM
