Going to attempt to build a box for dc lvl 4 m2 12" with m1 coil - Car Audio Classifieds!
Old 05-16-2014, 11:20 PM
graham's Avatar
Tinder Douchebag
0/11 sssss7122
Default Going to attempt to build a box for dc lvl 4 m2 12" with m1 coil
Short version: I'm thinking that the 1.5 cube after sub displacement that the sub is in now is good but the port area is too small and tuned too high.
Long version:
I have been building some small little DIY studio monitor type things for my computer and even with crappy used plywood that was left by the previous home owners, I managed to do a decent job. Not the best looking but turned out much better than I thought it would. So I figure I could try using MDF and building a sub box.
Right now the sub is in a 1.75 32hz box that was built for a 12w3. It does good but I can hear air being forced out of near the gasket on lower hz (28-32 I think)
I tried a box that was about 2.2 cubes with huge port and I was finally able to get voltage drop on about 30hz-ish - not only that, but there was no sound of air being forced out of the gasket area (I'm assuming this is because there was adequate port area that allows the air to properly escape)
Should I just keep the same design and just make the port area bigger and tune lower? I was thinking 26hz. Emphasis on low end response and stability.
Right now I peak at 41 but I hate anything above 36hz.
Any suggestions appreciated.
team graham
Old 05-16-2014, 11:31 PM
serjr711's Avatar
0/11 sssss2699
Feedback Score: 65 reviews
You're always welcomed to come over bro lol.
The Following User Says Thank You to serjr711 For This Useful Post:
graham (05-16-2014)
Old 05-17-2014, 10:15 PM
0/11 sssssss22
Lets build a box man
Old 05-17-2014, 10:23 PM
KickinBlazer's Avatar
0/11 sssss1122
if you want the peak lower...tune lower..around 26 to 28hz would get a peak around the high 30's....no more than 16 square inches of port per cube cuz any more than that and your lows will suffer try around 2 cube after all displacments
if its to loud your to old!
Old 05-17-2014, 10:36 PM
FocusOn20s's Avatar
'12 Focus Bangin
0/11 ssssss951
I had a DC Level 3 15 in a 3.25cf enclosure (suggested is 3cf) with about 16.5" of port area per cube and it got nasty
I've generally had GREAT results using not much more than .5cf suggested box size with a ton of port area.
Tuned at 30hz and was peaking at 33hz
2012 Ford Focus
Ampere Audio | SounDrive | Royal Excelene | STP Atlantic | Digital Designs
18" lvl 4 with lvl 5 coil kingtidis Car Audio Trader (WTT) 21 02-29-2012 07:50 AM
WTB 10" DC Lvl 3 with lvl 4 coil jarod027 Wanting to Buy (WTB) 0 03-12-2011 03:54 PM
Box Build 3 Lvl 4 15's NoPh33rRaCiNg Build Logs 59 03-19-2010 12:34 PM
[TRADED]WTT PSI LVL 1 12 for a box build orangelss Car Audio Trader (WTT) 7 02-19-2010 08:22 PM
[TRADED] 15" DC lvl 4 w/5 coil a_steezy 15" Subwoofers 9 12-05-2009 10:19 AM
