Box suggestions for 2 obsidian v3 15" - Car Audio Classifieds!
View Poll Results: Sub+port orientation.
Subs up port up 0 0%
subs forward port up 1 50.00%
Subs up port side 1 50.00%
Subs forward port side 0 0%
Subs up port forward 0 0%
Other (explain) 0 0%
Voters: 2. You may not vote on this poll
Old 05-24-2014, 09:59 AM
davidrforbus's Avatar
0/11 sssss6030
Feedback Score: 59 reviews
Default Box suggestions for 2 obsidian v3 15"
I should have both subs come Monday so I really need to get on the ball with my box. Thinking 7-7.5 cubes for the pair with around 120 sqin of port tuned around 36ish. Most likely gonna be slot port. Subs and port up in a ford ranger extended cab on a saz-1500v3. Just looking for some input if any of you would do something different. Thanks guys.
Old 05-24-2014, 11:07 AM
Kcbme's Avatar
0/11 ssssss526
I have the v2s but my box is a tad short of 11 cubes so about 3.6 cubes each and im tuned to 29 hz. If you like higher bass id suggest going about 35 or 36 hz like you said because mine lack the higher bass but thats what my mids are for. Just depends on what you like really.
2001 suburban
2.8:1 4th
4 db drive wdx 7k 18s on 2 crossfire 8ks
Old 05-24-2014, 11:11 AM
0/11 sssss6030
I like the lows like most everyone but I'd like to be able to play into the 40-45 with out it sounding bad. I don't really listen to much that goes into the 20s nothing below 25.
Old 05-24-2014, 11:17 AM
Kcbme's Avatar
0/11 ssssss526
I dont know exactly when I start to roll off but if I listen to normal music the bass just seems lacking(45 or 50 hz plus maybe), but I only listen to decaf for the most part so its not a problem for me. I would say anywhere from 32-36 hz would be a good place to start. Also dont forget to deaden your roof if you havnt yet before you install the box, I have my port on the passenger side and my roof still turns to jello with 2 layers of deadener I can only imagine a port facing up.
2001 suburban
2.8:1 4th
Old 05-24-2014, 11:23 AM
0/11 sssss6030
Yea roof is on my to do list. Appreciate it input.
Old 05-24-2014, 12:07 PM
Ryan1126's Avatar
0/11 sssss9178
i put a t3 t-600 15" in a ranger and did sub forward in the middle, port up on passenger side and it was loud.
Old 05-24-2014, 12:31 PM
0/11 sssss6030
I just think if I do subs forward they will be right up against the seat and hurt their performance.
Old 05-24-2014, 02:58 PM
0/11 sssss1882
Very possible if youre aiming for loud. On the other hand it would help your back and make the wife happy.
Btw, talk to murphy about some vibraflex if you dont already have deadener. Everyone who has mentioned it says nothing compares to it. Avoid peel and stick on the roof. Its only good for rattle traps.
Old 05-24-2014, 03:07 PM
mega fatty
0/11 sssss6008
I would do subs up port up
Port on passenger side
7cf with I like the 120" of port tuned to 35
Those OAS love the lows as it is so they can be tuned a smudge higher and still keep the lows hammering!
Old 05-24-2014, 03:43 PM
0/11 sssss6030
Yea I'm probably gonna need some kinda deadener, not sure what I'll get.
That sounds pretty good. If I can find some 6" areos I'd like to do two of them but I probably won't want to spend the money. When I had my 2 oa 12s that box was tuned at 32 and anything about 42 didn't sound good.
Need some suggestions on a box for 4 zv3 15"s Mnorwood01 (Sundown Audio) 18 02-26-2013 11:02 AM
obsidian 12" box size? Dunbar91 General Car Audio Discussion & Questions 2 08-28-2011 08:50 PM
Video: New box in the Rex. 3x 12" Obsidian D2's Electrodynamic General Car Audio Discussion & Questions 11 08-25-2011 12:49 PM
Obsidian 12" box build 95saturn General Car Audio Discussion & Questions 20 07-15-2011 09:01 AM
Suggestions? Box for 2 18" Nightshades? Biggy Team Sundowz 13 11-20-2009 07:08 AM
