2 DD 9512 3/4" Baltic Birch Box Help - Car Audio Classifieds!
Old 05-26-2014, 10:05 PM
0/11 sssssss13
Default 2 DD 9512 3/4" Baltic Birch Box Help
I am trying to build a sub box for my 2009 Scion XB [seats up] for (2) Digital Designs 9512's on (2) Audio Technix 1200.1 at 1 ohm. I am using (2) 3/4" 4' x 8' sheets of Baltic Birch and the max trunk space dimensions I have are:
Height = 24"
Width = 38"
Depth = 28" [20" from top of 45 degree angled backseat]
Picture for reference:
Looking for the best way to build my straight port box [how many cubes, tuning?, should I kerf the port?, subs facing up or back?]. All help is gladly appreciated, thank you.
Old 05-26-2014, 10:18 PM
G00burr's Avatar
0/11 ssssss591
subs up, port back. kerf is unnecessary unless you really want to
Old 05-27-2014, 03:34 PM
0/11 ssssss416
As long as you have plenty of port area a kerf isn't needed although you should at least round over the port on both ends.. Kerfing is mostly an aesthetic choice, assuming you have adequate port area to begin with.
Old 05-27-2014, 03:37 PM
BigBen's Avatar
0/11 sssss3006
Feedback Score: 24 reviews
2 threads same question?
Baltic Birch is So Expensive!! sbarber82 General Car Audio Discussion & Questions 19 08-20-2013 10:47 PM
Baltic Birch Plywood xnewbx General Car Audio Discussion & Questions 6 02-01-2013 09:09 PM
baltic birch vs luan plywood btsteinb General Car Audio Discussion & Questions 11 12-06-2011 11:32 PM
Tips on baltic birch benjdow Enclosure Discussion & Design Construction Help 14 03-26-2011 12:43 PM
