port help please - Car Audio Classifieds!
Old 06-04-2014, 05:06 PM
0/11 sssssss35
Default port help please
Im in the process of building a box for my 2 18" dc audio level 5 m1.here are my deminsions can you tell me if the port looks correct. Thanks in advance
Wood Thickness - 1 inches
Displacements - .52 cubic feet
Frequency - 29.49 hz
Box Length - 48 inches
Box Width - 37 inches
Box Height - 23 inches
Port Length - 30 inches
Port Width - 35 inches
Port Height - 5.5 inches
Gross Volume(Feet) - 19.57 ft³
Gross Volume(Litres) - 554.16 L
Net Volume(Feet) - 14.39 ft³
Net Volume(Litres) - 407.29 L
Port Displacement(Feet) - 4.66 ft³
Port Displacement(Litres) - 131.96 L
Port Area - 192.5 in²
Port Area(Metric) - 1241.94 cm²
Port Area Per Foot - 13.38in²
Port Area Per Litre - 86.32cm²
Old 06-04-2014, 06:20 PM
Jeffhulbert50's Avatar
Authorized Vendor
0/11 ssss14115
port looks fine
Old 06-04-2014, 07:54 PM
0/11 sssssss35
Thank you
Old 06-04-2014, 08:10 PM
0/11 ssssss322
Any way you can get that port closer to being square? 35x5.5 is quite skinny. It will work, but will be less efficient and therefore not as loud as a more evenly shaped port.
Also, wish i had room for a 20 cuft box!!!
What is your bracing displacement?
2012 North American Street Stock Runner-up - 150.9 on 1800 clamped watts (Teammate)
2013 dB Drag Street Trunk World Champion - 153.9 on 3200 clamped Watts (Teammate)
2013 MECA Trunk 1 World Champion - 152.8 Headrest (Teammate)
2013 MECA Park & Pound 2 World Champion - 130.6 (Teammate)
Checkout our build and videos !! : )
(click for Hairtricks)
Smith's Custom Seats
Martinsburg, PA
Old 06-05-2014, 03:31 AM
Boomintahoe's Avatar
Hurtin' Feelins' errrday
0/11 ssss12531
A square port or rectangle port....I wouldn't think there would be a difference in SPL if using same subs. They don't have to be even imo.
'97 4 dr. Tahoe
Alpine 9835
Polk Audio MM6501
Old 06-05-2014, 06:41 AM
0/11 ssssss322
When your length to width ratio is large, you have more surface area in the port per cross sectional area. It's the same theory why one large port is better than multiple smaller ports. Round has the best ratio, then oval, squares the next best, and then rectangle.
Think of it this way. You have an 8" round port vs a 25" x 2" slot port. They are both 50in^2 of cross section, but the round has 25" of surface area in the port vs 54" for the slot port.
Port is everything....and the more efficient it is, the louder you can get on a given amount of power.
Martinsburg, PA
The Following 2 Users Say Thank You to SCS_Audio For This Useful Post:
97_eldo (06-05-2014), massivespl (06-06-2014)
Old 06-06-2014, 04:14 AM
0/11 ssss12531
I haven't seen, if none at all, oval ports....show me someone using one right now?? Round isn't always best simply because lots of bassheads use vents...rectangle or square to gain the most SPL possible. Or even a daily street beater yields the same. I also might add that square has more area than round.
I agree somewhat port isn't all that. It's also in the box too. A properly designed and built one.
I don't think you follow my reply. So if I had a choice of a vent either square or rectangle for the same enclosure, same subs, same power, same ratio, same vehicle, same area in the vehicle the sub enclosure is going in, ....I don't think the shape of the port would matter. Would it?
'97 4 dr. Tahoe
Alpine 9835
Polk Audio MM6501
Old 06-06-2014, 05:46 AM
0/11 ssssss322
Someone using an oval port? How about the one my friend Jordan Smith and i built lol. DbDrag Street trunk 4K loudest car from last year. It's oval because it maximized port area, but stayed as close to round as possible. It's all about airflow. Corners, sides, bends, non flared edges, they all impede airflow and that is a bad thing.
As far as square being larger than round.... you are not following my mathematics. I am finding the ratio of cross sectional area as it compares to surface area (wall area). Yes a 10" x 10" (100 sq-in) square port has more cross sectional area than a 10" round. But, what I am saying is, it also has more wall surface area (and corners) than a comparable 11.28" (100 sq-in) round port. It has about 113% more surface area for the same cross section.
Martinsburg, PA
massivespl (06-06-2014), Todd Dupler (06-06-2014)
Old 06-06-2014, 05:59 AM
craiggus365's Avatar
Partially Unwound
0/11 sssss2697
This is another example of oval port:
Todd Dupler 01 jetta build log
The Following User Says Thank You to craiggus365 For This Useful Post:
Old 06-06-2014, 07:49 AM
0/11 ssssss322
Yea, Todd's daily port on page 4 is an oval with about the same shape as ours. Hope we see him at a show this year! I really want to hear it!
His SPL port is technically a slot port with rounded ends since an oval has no flat sides, but he was doing exactly what we were doing...trying to fit as much port in there as possible lol !!!
Martinsburg, PA
Cartunz 3X show 6-24-2012 $500 for loudest non Port or Super Port score bdufner Competition Corner 2 06-16-2012 07:29 AM
