60 cube to work with ?? - Car Audio Classifieds!
Old 06-07-2014, 02:21 AM
0/11 sssssss31
Default 60 cube to work with ??
Hi guys , as title says I have 60 cube internal to play with , I would like to play from 20-55hz , reasonably flat and sound musical ! Pref using 18's or 15's.
I would like to play propper droppers here in the uk with it , testing at 20,25,30,33 hz and also use for music so an interchangeable port is fine.
I have 3 x 5k @ 1ohm amps ,subs undecided until I can make the most of the airspace.
what would you suggest ?? Yeah 60 cube ain't much compared to some of the huge vehicles u guys have over there lol Thanks for any input !
Old 06-07-2014, 03:57 AM
0/11 sssss1417
large ported flat wall. tuned high 20s. 4 18s.
ridintwo6s's Avatar
0/11 sssss1791
60 internal is actually a ton compared to most builds.
you can do 16 12s, 8 15s, 12 15s, you really have a TON of options. the best way to be good for thsat format is gonna be to test, test, and test some more different port areas and tunings.
good luck.
2013: 4 12s no wall mid 50s
Team HateD
Team Sundown
129.9 SBN 2013 Champ
Old 06-07-2014, 03:58 AM
0/11 sssss1417
maybe pick your subs first.
Old 06-07-2014, 05:07 AM
Boomintahoe's Avatar
Hurtin' Feelins' errrday
0/11 ssss12531
This.
Or are you asking, OP, what sub's to get?
'97 4 dr. Tahoe
Alpine 9835
Polk Audio MM6501
Old 06-07-2014, 05:29 AM
Todd Dupler's Avatar
Team SPL Farms
0/11 sssss5000
6-Death penalty 21d2s w room to spare
01 Volkswagen Golf 2 door
Kenwood ddx470
Old 06-07-2014, 05:55 AM
e46inperrycounty's Avatar
SPL Farms
0/11 sssss5706
~2:1 ratio 6th order with 2 tantric Shd 24's and sell the third 5k amp. Rear chamber at 20hz, about 20 cubes, front chamber at 38-40hz with about 40 cubes.
2 Ampere 3.0v2 18's
BC5500 at half ohm
Mark Antony gs380.4
Anarchy 6.5s
AB sq6b's
Team SPL Farms
Old 06-07-2014, 08:43 AM
mega fatty
0/11 sssss6008
4th order with 12 15's
25cf rear 35 tuned to 45ish
Or even just do a diamond with 12 15's or something of the sort
Old 06-07-2014, 08:59 AM
craiggus365's Avatar
Partially Unwound
0/11 sssss2697
I have no advice on the subs, but what does "I would like to play propper droppers here in the uk with it" mean? Is it a competition circuit?
Old 06-07-2014, 09:08 AM
666WMD's Avatar
No idea what I'm doing
0/11 sssss1307
He wants to get low and loud. It's spl at low frequency.
http://www.propperdroppers.com/
Would a 14" diameter aero port work in a 17.5 cube??? Mnorwood01 General Car Audio Discussion & Questions 3 11-22-2013 10:19 PM
5.5 cube center Aeroport enclosure Conclusive1 Wiring, Electrical & Other Installation Equipment 12 11-20-2012 04:28 PM
OG Phoenix Gold Bass Cube Jolly Green Giant Head Units, Processors & EQs 4 04-13-2011 08:05 AM
[SOLD] Pg bass cube CRACKERJACK Head Units, Processors & EQs 8 01-19-2010 05:45 PM
1.75 cube my_son_is_my_life General Car Audio Discussion & Questions 4 12-03-2009 08:14 AM
