6th order port - Car Audio Classifieds!
Old 06-10-2014, 10:55 PM
0/11 sssss4519
Default 6th order port
So I'm going to change my 4th order to a 6th order for a little while to see if I like it before I shrink my rear chamber. My question is, how much port? its 13.75 cubes for 5 HD15s on 6k. I was thinking one 8'' sonotube at 25hz.......... I can do a port in either the red, blue, or both circles.
To find sealed resonance
resolve Vas/28.32 =
result of that +1
square root that result
Old 06-11-2014, 12:44 AM
0/11 sssss1411
from what ive read about 6th you would take "normal" size port for those subs on a regular ported box and basicly shrink it by half - in the hopes to control sub suspension when playing under tuning. also whats your front chamber going to be tuned to ?
and are you chasing numbers or wanting to play a large bandwith ?
for numbers you can keep the rear tune closer to the front tune
for daily music and ground pounding you could tune the rear in the 25 to 30 range and the front somewhere 55 to 60hz and play a pretty strong bandwith from 20s up to 60s
Old 06-11-2014, 12:57 AM
0/11 sssss4519
It needs to be a mixture of both. a Loud ass Daily driver. I'm going to try squeezing in two 8'' sonotubes at 25hz and go from there. My front chamber is 50hziirc but i need to double check everything
resolve Vas/28.32 =
result of that +1
Old 06-11-2014, 01:00 AM
0/11 sssss1417
Around 6-8 per cube for aero
6th/4th Order Front baffle/port. STAINLESS STEEL!! bigdhenderson Wiring, Electrical & Other Installation Equipment 17 12-29-2013 10:25 PM
6th order, too much rear port? stssilverado Enclosure Discussion & Design Construction Help 6 08-02-2013 08:16 PM
6th order bp port area, help! 321slapinbass Enclosure Discussion & Design Construction Help 4 08-28-2012 12:28 PM
Quasi 6th Order Bandpass port orientation... quagmire Enclosure Discussion & Design Construction Help 10 06-07-2012 10:23 PM
