Mounting amps to back wall of truck - Car Audio Classifieds!
Old 06-18-2014, 01:27 AM
0/11 sssssss86
Default Mounting amps to back wall of truck
What's the best way to mount amps to the back wall of a truck?
I'm redoing the system in my Dodge and used to run one 4 ch amp under the driver's seat. I'm upgrading to a 4 ch for the front stage and a mono for the sub stage and the amps I bought (dsc4125/dsc1500.1d) won't fit under the seats.
I figure the best place to put them is on the back wall of the cab above my enclosure but I've never done that before. I'd prefer not to drill holes into the sheet metal of the cab.
Here's the space I'm working with...
Old 06-18-2014, 01:55 AM
graham's Avatar
Tinder Douchebag
0/11 sssss7122
Unscrew those hook things, use same bolts or same type of bolt to mount a piece of wood on there. (or 2)
Then use t-nuts on the back side and appropriate length bolts to fit into the t-nuts to mount the amps. You could also use wood screws, but you get more coverage with t-nuts and they are real cheap.
team graham
Old 06-18-2014, 04:03 AM
Boomintahoe's Avatar
Hurtin' Feelins' errrday
0/11 ssss12531
Yup...graham said it pretty well. Take a scrap piece of MDF and use the existing hooks bolt holes and mount that piece of wood on there with the amp screwed down or bolted to the wood.
I've also seen some amps mounted on top and on the side flush mounted around a large sub box in the extended cab area.
'97 4 dr. Tahoe
Alpine 9835
Polk Audio MM6501
Old 06-19-2014, 08:33 PM
0/11 sssssss86
Thanks guys. That's a great idea about reusing the existing bolt holes. I'll have to see what I can come up with.
Old 06-21-2014, 04:40 PM
graham's Avatar
Tinder Douchebag
0/11 sssss7122
Try to take that black box out and get more pictures if you want any more suggestions.
Post some pics when it's all done too. I would love to see how it turns out.
team graham
Old 07-06-2014, 10:05 PM
The_Dealer's Avatar
0/11 ssssss212
Did basically the same thing in my Silverado with a sheet of mdf. Removed some crap that was already bolted to the cab and secured my board with it. I didn't use t-nuts, that's a very good idea
Old 07-08-2014, 03:34 AM
0/11 ssssss535
I epoxied a piece of mdf to the back wall after removing the carpeted piece in my brothers 2010 ram QC. Then I trimmed the carpeted piece to fit around the amp.
Old 07-08-2014, 10:05 PM
0/11 sssssss86
Will do. There's been a delay in getting started as I'm having some steering issues with it. I'm hoping to started on it next week.
Old 07-08-2014, 10:38 PM
RobertByers's Avatar
0/11 ssssss180
I removed the factory carpet panel and had space to install a sheet of 1/2" behind it and reinstalled the panel. If I ever go bigger with amps I'd remove the entire factory panel and make a custom one.
Bringing back Funkin' Audio - One truck load at a time old CACO Admin (DIYMA.com) 44 02-18-2013 12:24 PM
Mounting Amps on the back of fold down seats? ImpalaOnDubs General Car Audio Discussion & Questions 9 07-16-2012 03:17 AM
back seat non wall build ideas Russellabt General Car Audio Discussion & Questions 20 04-05-2011 03:14 PM
10 in AQ HDC3 under a truck back seat Nebraskachevy General Car Audio Discussion & Questions 9 07-25-2010 04:16 PM
how far does an AERO port need to be from the back wall? SacTownBully84 General Car Audio Discussion & Questions 3 06-23-2010 11:54 PM
