DD3515 with carbon fibre dust cap dual 2ohm - Car Audio Classifieds!
Old 09-06-2009, 11:15 PM
0/11 ssssss196
Default DD3515 with carbon fibre dust cap dual 2ohm
well im the proud owner of one of these DD3515 dual 2ohm, i have about 40.5 inches width 14 inches deph 16 inches height external 1inch all round 2 inch baffle roughly 4.45cft with out speaker displacement. not sure on what the best tuning for dd3515 is in that size cab,
can any one tell what motor is fitted from pics? weight of speaker was 11kg magnet was 3 inches rough height. weight 388 ounces.
found this for displacement is this correct DD 3515 = 0,252 cuft, i can find parameters for 3515c but not my version 3515 does any one have params for this driver? thanks in advance.
Old 09-07-2009, 12:32 AM
0/11 sssss1741
Originally Posted by thecat666 View Post
i was also told that the carbon fibre dustcap doubles rms is this true can any one tell what motor is fitted from pics if so please tell thanks in advance.
Seriously? Someone told you that?
Also, i am not sure if you are aware that the front is going to be a little bit more work than a standard box, assuming you are going to make a slot port on the front of the box. I just got done making a box for a 9515, where my height was only 16" high in the front, i had to make the front baffle one complete piece even around the port, had i not done that there would not have been any support or anything left where the sub cut out whole was, which is about 14" for the sub cut out. It can be done tho, mine turned out fine. Here are some pics of it.
Hopefully you can see what i am saying. The front piece is one piece, it was cut out around the port.
I am unsure of what you want to tune it to. As far as i know DD's are made to be tuned in the higher range of most subs, like around 40 or so, but i hear of people tuning quite lower with no problems. I tuned my 9515 to 37hz and i think thats a good frequency IMO.
Old 09-07-2009, 12:42 AM
0/11 sssss6061
The dust cap on those are made to resist folding during extreme spl usage.
Old 09-07-2009, 01:03 AM
0/11 ssssss196
found 3 stickers hope this helps.
11-2004 i know this one build date
DD35K 2/2 not sure about this i no its dual 2ohm dont know what k means
11445 dont know what it means
Old 09-07-2009, 01:12 AM
0/11 sssss6061
Might have better luck emailing DD honestly.
Old 09-07-2009, 01:35 AM
0/11 sssss1741
That would mean 3500 series, which is the series you have. Dono what that other means.
Old 09-07-2009, 02:08 AM
0/11 sssss6061
Probably an E series.
12" FiQ Dual 2ohm bhamack 12" Subwoofers 6 11-20-2009 04:42 AM
[No longer for sale]F/S - Digital Designs 2510a w/ Carbon Fiber Dust Cap SundownAudioNY 10" Subwoofers 2 06-19-2009 11:06 AM
2 Ascendant Audio Havoc 18 Dual 2ohm j_black10 18" Subwoofers 28 02-10-2009 07:10 PM
Two (2) BNIB DD9515G's D4, Comp Cone, Carbon Fiber Dust Cap, Stiff Spiders gundecker 15" Subwoofers 9 09-22-2008 03:10 PM
[SOLD] Fi Q 18" dual 2ohm $200 shipped Derrick824 18" Subwoofers 17 09-21-2008 10:33 PM
