I need a basic design for 1.75-2.25 cube 1x 12" slot port 3/4" MDF - Car Audio Classifieds!
Old 06-25-2014, 05:28 AM
graham's Avatar
Tinder Douchebag
0/11 sssss7122
Default I need a basic design for 1.75-2.25 cube 1x 12" slot port 3/4" MDF
I need a basic ass design for a single 12", 1.75-2.25 cubes ported, tuned to 20-28. Tuned to 32 now, car peaks at 41, which I hate, so I'm trying to get the peak lower. I prefer 25-36hz. Closer to 28-34 though.
In return: I can offer paypal (since I actually have some paypal funds right now) or some cool trades. But I don't need anything fancy. I'll figure out the double baffle/flush mount myself.
Now I'm thinking sub/port up due to sub/port back acting more punchy, and I assume sub up/port back will act the same way. I prefer the longer deeper notes over short punchy ones, and keeping the box in a sub/port up orientation seems to accommodate my preference nicely.
I have 38"x12x"20" to work with. Width, length, height. Although I would love to build a box that fits into the slant on the back seats, if that isn't too hard to do?
Open to any feedback/suggestions as well.
team graham
Old 06-30-2014, 07:25 PM
The_Dealer's Avatar
0/11 ssssss212
What sub/amp are u using, and do u need a cut sheet? I have a few designs I did when I was looking at running an XFL12
Old 06-30-2014, 07:34 PM
e46inperrycounty's Avatar
SPL Farms
0/11 sssss5706
With that small of an enclosure it will not be easy to achieve that tuning with enough port area to promote a wide freq range or much efficiency above actual tuning...
2 Ampere 3.0v2 18's
BC5500 at half ohm
Mark Antony gs380.4
Anarchy 6.5s
AB sq6b's
Team SPL Farms
Old 06-30-2014, 07:52 PM
graham's Avatar
Tinder Douchebag
0/11 sssss7122
Right now, a single dc lvl 3 d2 (final load is 1.3 though) on a saz1500d v1
I know the port area is too small and port tuning is probably a little high for what I want.
I don't need a cut sheet if it's going to cost more.
I only want response from about 28-36hz though. My car peaks/resonates at 41hz, but anything about 36hz just sort of "hums" so I pretty much hate anything above 36hz.
Are you saying there is no way to get tuning that low at all? I can make the box bigger. I have a lot of room to work with.
team graham
Old 07-01-2014, 06:35 PM
The_Dealer's Avatar
0/11 ssssss212
I'd go with about [email protected]
Old 07-01-2014, 09:25 PM
0/11 ssssss322
1. If it sounds that bad, maybe you should get some deadener? It shouldn't sound bad.
2. I dont think you need a double baffle for 1 12" and 1500 watts. You have no large spans. If you need more volume, I would not worry about it if space is tight.
3. The dimensions you gave give you 4.1 cuft to work with, any reason you want to stay around 1.75-2.25? The more volume, the easier it will be to tune low.
4. You will need your port to run with the longest dimension you gave. Is the 38" from left-right in the car? Would you have room for a port to come out the side?
5. I would highly recommend against a 1"x12" slot port, especially if you plan on bending it, and not flaring it. That will be be very inefficient.
My recommendation would be; if you can get your internal volume to be about 3 cuft after displacement, and put a 6" round port in it at about 33" in length. That would be a nice low box, tuned to about 25-26.
2012 North American Street Stock Runner-up - 150.9 on 1800 clamped watts (Teammate)
2013 dB Drag Street Trunk World Champion - 153.9 on 3200 clamped Watts (Teammate)
2013 MECA Trunk 1 World Champion - 152.8 Headrest (Teammate)
2013 MECA Park & Pound 2 World Champion - 130.6 (Teammate)
Checkout our build and videos !! : )
(click for Hairtricks)
Smith's Custom Seats
Martinsburg, PA
Old 07-02-2014, 04:50 PM
The_Dealer's Avatar
0/11 ssssss212
Here's what I came up with, I can do you a larger one of you'd like
As stated, if you go on the larger side 2.5-3cuft, it would be easier to achieve more port area. Imo, even flaring a 1x12 port would still be inefficient. I like to stay below 1:8 width to height ratio
Would a 14" diameter aero port work in a 17.5 cube??? Mnorwood01 General Car Audio Discussion & Questions 3 11-22-2013 10:19 PM
18" (Sub Up/Port Back BASIC)Box request for Jdubs04ss Jdubs04ss Box Requests 1 02-07-2012 06:33 PM
Help with port 15" AQ hdc3 alum in 3 cube box djseven Enclosure Discussion & Design Construction Help 7 08-04-2010 03:19 PM
What is a "slot" port? aturcotte127317 Enclosure Discussion & Design Construction Help 3 06-18-2009 03:22 PM
