2 sa 15's extended cab enclosure help. - Car Audio Classifieds!
Old 06-26-2014, 08:45 PM
Mike stuber's Avatar
0/11 ssssss349
Default 2 sa 15's extended cab enclosure help.
I traded my sa 8 v2's for some sa 15's and now I need an enclosure. I'm running a hifonics brutus elite 2500.1 @1 ohm so probably seeing around 2000 watts. My question is how many cubes should I shoot for? I know that when you run more than rated power you can build smaller but how small. The box is for a 01 s10 extended cab I'm thinking sub's forward on drivers side and port firing up passenger side. Here is what I've come up with for a box so far done on the BTC app on my phone
24 tall
16 deep
44 wide.
Which should be 8.02 cubes that includes the displacement of subs
Port 32 long
13.5 wide
7 high = tuned to 34.5 hz
So if the app is correct it should be 5.36 cubes after port displacement with 94.5 in2 of port area. Does that seem too small for 2 sa 15 on about 2k? Could someone maybe model it for me that would be awesome. Thanks in advance the expertise is greatly appreciated. And I'm always open to suggestions.
extended cab p/u...which one?? Boomintahoe General Automotive Chat 31 05-22-2015 06:32 AM
Best port/sub configuration in an extended cab? westman995 Enclosure Discussion & Design Construction Help 5 06-23-2013 09:22 PM
BESt 10" sUB FOR EXTENDED cab?? Jesus805 General Car Audio Discussion & Questions 4 10-01-2012 12:47 PM
09 Silverado Extended Cab Substage Hertz5400LincolnLS Enclosure Discussion & Design Construction Help 3 03-08-2011 07:57 PM
Best option for extended cab silverado ado General Car Audio Discussion & Questions 5 11-02-2008 11:12 AM
