please help me with plans!! - Car Audio Classifieds!
Old 06-28-2014, 11:30 AM
Ryan1126's Avatar
0/11 sssss9178
Feedback Score: 59 reviews
Default please help me with plans!!
cliff notes: looking for plans for a box to fit under the back seat of a 2002 silverado extended cab that is ported for two 10's ([email protected] common chamber or a separate chamber with [email protected] each side or lower tuning is fine)
i got a friend that wants to get two 10" RE SX-X's under the backseat of his 2002 silverado extended cab. He wants them ported.... he had them in a box already that was subs forward port forward. its probably some flea market box that is nowhere near specs, its supposedly 1.25cuft tuned to 35 hz in each chamber which is hard for me to believe with a port that is 3" around by 9 inches.... the issue is the box is made of 5/8" mdf in some places and 1/2" in others, total hack job and he wants it rebuilt to better specs but im starting to think it isnt possible with the space given UNLESS someone has some type of magical plans i can use.
Old 06-28-2014, 11:38 AM
socalxj's Avatar
0/11 sssss2371
Once upon a time there were lift brackets for the rear seat. When I made enclosures I was able to get 2 8's under the rear seat but not 2 tens. The enclosure's subs and ports fired forward.
Old 06-28-2014, 11:40 AM
Ryan1126's Avatar
0/11 sssss9178
this is what i figured, i tried to tell him that there just isnt enough room but since he has this box he thinks it is possible but first of all i doubt it is 1.25cuft in each side and if it is they used thinner mdf to achieve it.
Old 06-28-2014, 12:40 PM
Kcbme's Avatar
0/11 ssssss526
He could look into shallow mount subs,I had a friend run 2 jl audio w1 10s ported under the seat in his f150 and I couldn't tell they where shallow mount till he told me.
2001 suburban
2.8:1 4th
4 db drive wdx 7k 18s on 2 crossfire 8ks
Old 06-28-2014, 12:51 PM
Ryan1126's Avatar
0/11 sssss9178
he doesnt want to he is set on the sx-x's
Old 06-28-2014, 01:02 PM
craiggus365's Avatar
Partially Unwound
0/11 sssss2697
How about fiberglass?
The CAF vids on the 'tube will show you basic skills and materials needed.
Prob have to fire the subs up into the seat though.
Old 06-28-2014, 07:21 PM
Ryan1126's Avatar
0/11 sssss9178
not worth it im only charging 180
Old 06-30-2014, 08:20 AM
andy75's Avatar
0/11 ssssss788
I have a 01 gmc ext cab. Currently building for 2 dd 9510's under rear seat, I have 3.44 cu ft gross with no seat lift. I'll get some pics later but rough measurements off the top of my head are 11.25 high front, 6" high back, driver side 22" wide, hump 17" wide, pass side 18" wide and about 14" deep. External measurements. Back wall is leaned back, and I have the top cut out and extended 1.5" to take up void under seat cushion.
Clear as mud, huh? Lol
Old 06-30-2014, 08:39 AM
0/11 sssss1417
Old 06-30-2014, 06:57 PM
andy75's Avatar
0/11 ssssss788
That top extension was worth .44 cu ft.
payment plans agp1976 Tutorials & Quick References 15 06-22-2014 09:10 PM
Need Help With Box Plans Raptor660 General Car Audio Discussion & Questions 1 02-19-2012 06:05 PM
Jacob, Any plans for sound_around (Sundown Audio) 28 10-25-2010 12:40 PM
Change in Plans Bryan General Car Audio Discussion & Questions 0 05-18-2010 01:25 PM
Weekend plans? Patrick Simmons Off Topic Chat 81 11-07-2008 11:16 PM
